Hyundai Aftermarket
-   HELP Forum (https://www.hyundaiaftermarket.org/forum/help-forum-21/)
-   -   my clutch pedal is squeeking! (https://www.hyundaiaftermarket.org/forum/help-forum-21/my-clutch-pedal-squeeking-9485/)
blktib Oct 29, 2001 08:45 AM
ok, my clutch pedal is squeeking! what should i do?
Random Oct 29, 2001 07:43 PM
Step on it? :D
Install a mousetrap under the pedal? :D
Seriously...lube up the slider in the engine compartment. That is what is sqeeking. Have a friend pump the pedal a few times and you will see the arm moving in the engine compartment. Just put a couple of DROPS of oil on that arm, and the pivot point, and it will quiet right down.
Curtas Oct 29, 2001 09:54 PM
Random,
any particular type of oil? 3 in 1? WD40?
I've been living with this problem for a year now and would LOVE for it to go away.
thanks,
ac
Random Oct 30, 2001 02:37 AM
I just use good old fashioned motor oil. 3in1 oil would probably do the trick too.
blktib Oct 30, 2001 12:37 PM
hmmmm. i got the inside worked on. WD-40 and I don't think i hear any squeeking anymore. smile.gif I should get the engine compartment also. Thanks.
Random Oct 30, 2001 02:11 PM
Only problem with wd-40 is that it dries out fast. Your clutch may be squeeking again in about a week!
blktib Oct 31, 2001 11:16 AM
Really! ok, then some motor oil.
Jay Nov 10, 2001 11:45 AM
White grease works the best. Clutch has a nylon bushing, which sometimes can dry out a bit over time helping to cause this squeak (and for me, a bit of rubbing as well) Spray some white grease over it in engine compartment as Random explained where it is, pump the pedal a few times and you should be good to go.
