Hyundai Aftermarket
-   HELP Forum (https://www.hyundaiaftermarket.org/forum/help-forum-21/)
-   -   Loud squeeking (https://www.hyundaiaftermarket.org/forum/help-forum-21/loud-squeeking-56891/)
AtomicX Sep 7, 2010 07:04 PM
Loud squeeking
Hey this just started happening about 2 days ago. When I start my car up, a VERY loud sqeel is coming from around the pulley area. It eventually stops after 1 minute of idling, but starts back up when being in a low gear and turning. If I turn the steering wheel all the way one direction, the loud squeel comes back and the battery light slowly comes on, but shuts off once i release the steering wheel. Any Ideas?
faithofadragon Sep 7, 2010 07:06 PM
belt is loose
AtomicX Sep 7, 2010 07:09 PM
<div class='quotetop'>QUOTE (faithofadragon @ Sep 7 2010, 09:06 PM) <{POST_SNAPBACK}></div><div class='quotemain'>belt is loose</div>
The belt on the power steering pulley appears to be tight, going to check the belt on the alternator now.
EDIT:
Just checked the altenator, is there suppost to be 2 nuts on each side of this?
https://i88.photobucket.com/albums/k...00907-2112.jpg
faithofadragon Sep 7, 2010 07:18 PM
that little block is threaded
still say your belt is loose expecially if the battery light flickers
WytchDctr Sep 7, 2010 07:18 PM
one side, the block itself is threaded for the longer bolt . You are missing a nut
faithofadragon Sep 7, 2010 07:24 PM
hmmm i thought both sides where? oh well im not running the stock setup anyways to remember
looks like you lost your nuts
WytchDctr Sep 7, 2010 07:41 PM
You were half right. The longer bolt has threads for it, the smaller one needs a nut, at least that is how mine is setup.
AtomicX Sep 7, 2010 08:47 PM
<div class='quotetop'>QUOTE (WytchDctr @ Sep 7 2010, 09:41 PM) <{POST_SNAPBACK}></div><div class='quotemain'>You were half right. The longer bolt has threads for it, the smaller one needs a nut, at least that is how mine is setup.</div>
Yup thats how mine is. I just tightened the threaded bolt, put a new washer + bolt on the horizontal side. No sqeeks, works nicely now.
HyundaiKitCoupe Sep 7, 2010 10:58 PM
if you ever get belt squeal, you can spray carb cleaner into the grooves. it'll stop the noise for a while temporarily. i always do it when my belts get loud.
faithofadragon Sep 8, 2010 07:07 AM
carb cleaner eats rubber
so you just reduced the life of your belts
