Loud screeching noise
Old Nov 23, 2008 | 04:46 PM
tibbykid91's Avatar
Vehicle: 2008 Tiburon
Default Loud screeching noise
When I start the car in the morning and it is less than like 40 degrees there is a loud screeching noise that lasts like 30 seconds, this same noise happens when I turn the steering wheel all the way left of right. Any guesses at what could be causing this noise. The car is a 2000 Tiburon.
Old Nov 23, 2008 | 05:00 PM
Get a new power steering belt, or check yours and tighten it a bit if it's loose.
Old Nov 23, 2008 | 07:05 PM
Cypher's Avatar
Vehicle: 2002 Hyundai Elantra
Take a look at the belt. Is it properly tensioned? also look at it for signs for dry rot.
Old Nov 25, 2008 | 02:29 PM
tibbykid91's Avatar
I just had to tighten it. Thanks.
Old Nov 25, 2008 | 09:26 PM
hammondfra's Avatar
Vehicle: 2003/Hyundai/Tiburon
QUOTE(tibbykid91 @ Nov 23 2008, 06:46 PM)
Yes the belt is tensioned...if you have never changed it or has been a few years you will need a new one as they strech out of original shape. The squeel you hear is the bult slipping over the pully...and it will do it when you turn the wheel (pump is operating at a higher function) or accelerate fast from a idle and every now and then if you hit a puddle of water.
