Inner Tie Rod Replacement!
Hello guys, my car needs an inner tie rod. My mechanic wants something crazy to do it and I keep hearing I need a special took to remove it.
I checked for a DIY for this, but nothing :( What is involved? Should I just let my mechanic do it? |
how much is he charging you for it?
Umm the only special tool you should need is a pickle fork.
This should be all thats involved: Use pickle fork to pop off outer tie rod end. Pull boot from inner tie rod end. Remove the nut holding the inner tie rod on. Mark the location/distance of your outer tie rod before putting it on the new inner. Torque it all down and check your alignment. |
That's for the outer tie rod.
Originally Posted by krazytib
(Post 625080)
For the inner he needs either a big Crescent wrench or a inner tie rod removal/installer tool. It's a long tube with different wrench adaptor to use on differnt cars and then you turn it with a 1/2" wrench. You can buy this at Harbor freight or buy a name brand one from Lisle for like $70. You cant see the hex part that you need to turn untill you remove the boots. It is very possible to do it with a crescent wrench by doing one side at a time by turning the wheel all the way to one side which puts the tie rod as far out as possible to you can get to the 4 sided part of the inner rod that needs to be loosend. |
| All times are GMT -6. The time now is 09:07 AM. |
