Help With Cams
Old Aug 6, 2002 | 05:53 AM
Redliner's Avatar
Vehicle: 2001 tib
Default Help With Cams
I'm just about to order the RPW racing cams. But after reading your posts which state that the cams in the 1.8l engine is better than in the 2.0l, I am having second thoughts. How much more lift will it provide and how many horsepower gains and torque can I expect? Is it worth it for me to order the RPW cams?
P/s: I have a 1996 1.8l Hyundai Coupe
Old Aug 6, 2002 | 06:13 AM
JAWS 021's Avatar
nobody has dynoed RPW cams... so i cant tell you how much hp youl get out of them
as for the lift... ask them... they should know
email customerservice@sharkracing... they distribute for them
BTW... depending on how aggressive the cams are, you might need to get them tuned
An safc should remedy that
Old Aug 6, 2002 | 06:39 AM
Veniston's Avatar
RPW Cam specs are on SharkRacing's website.
Can't recall the elantra cam specs offhand, but it says a bit about the difference from the 2.0 tib on Sharkracing, here. You may turn up something in a search of this forum.
Old Aug 8, 2002 | 07:16 AM
4CyLofFuRy's Avatar
which cam will give you more power? the 1.8L or the elantra gt cam?
Old Aug 8, 2002 | 07:42 AM
9o7TiB7o9's Avatar
The more power you get out of the cam...the less driveability will result. Also if you ever plan on going forced induction (turbo in particular) then don't bother, save the money up because you cannot use N/A Cams after doing so...and if you do...i believe its not worth it...or something around in that area.
