Head light spring clip
Old Jan 24, 2009 | 08:32 PM
SUZONKA's Avatar
Vehicle: 1999/hyundai/accent
Default Head light spring clip
I tried to replace the H7 bulb in my 2001 sonata, the spring clip is giving me trouble getting it off, is it only hooked on one side to remove it or hooked on both sides of the spring that goes over the bulb into a hook shaped clip
Old Jan 25, 2009 | 03:28 PM
omeletduefromage's Avatar
Vehicle: 02/hyundai/accent
its hooked on one side and screwed in tight on the other. remove the headlight and then remove the screw holding the clip down and put your hand in front of the spring so when it goes flying you dont lose it or become a casualty or shrapnel wink.gif
