Getting Big Bore Thottle Body and Short Shift...help. :)
Old Jan 5, 2002 | 02:51 PM
Jeremy S.'s Avatar
Default Getting Big Bore Thottle Body and Short Shift...help. :)
All,
I just put an order in for the short shift kit from SR and the SR 58mm Throttle Body. I need to know AS MUCH INFO AS I CAN GATHER about the ins, outsm tips, ideas, and headaches if any, I am getting into with these two toys. Please, let me know. ANY AND ALL help is GREATLY appreciated. smile.gif
Sincerely,
Jeremy S.
TSR 228
Old Jan 6, 2002 | 03:36 AM
The only tip or trick with the BTB is that your coolant hose that feeds the TB will have to be routed back on itself. Very minor. You may not understand now, but when you remove your stock unit, you will see.
The Short Shifter install is fairly easy.
Use this as your guide. http://www.speedstate.com/Hyundai_Section/...hort_shift.html
