funny sounds
Old Dec 22, 2001 | 09:36 PM
ozwald300's Avatar
Default funny sounds
When I let the clutch out (without touching the gas)my car makes a funny clicking noise from the floor by the pedals only does it in 1st,and reverse.(2001 tiburon) thanks
Old Dec 22, 2001 | 11:32 PM
J@WS 01's Avatar
How many miles on your tib?
In my experiences in the shop, I've found that the clevis pin that connects the clutch pedal and clutch master cylinder to be faulty, try removing the clevis pin and rotating it 180 degrees and reinstall it nd give it a try.
Old Dec 23, 2001 | 03:07 AM
redturbulance's Avatar
Vehicle: 2001 Hyundai tiburon
Mine does this to and it is a 2001. Correct me if i'm wrong but do tibs have hydraulic clutches. I'm not sure but mine always does it when it is cold thus my reasoning behind the hydraulic part.
Old Dec 23, 2001 | 03:29 AM
J@WS 01's Avatar
yes it is hydraulic clutch, but the clevis pin is the mechanical connection to the clutch master cylinder.
Old Dec 23, 2001 | 04:36 AM
ozwald300's Avatar
It's a 2001 and it only has 3000 miles on it
Old Dec 25, 2001 | 02:05 PM
ozwald300's Avatar
does anybody else have an idea what it is I take it tommarow and I'm kinda worried.
Old Dec 25, 2001 | 04:53 PM
My guess is that it is your Clutch starter switch that will not let you start the car unless the clutch is pushed in. It is probably just noisy. It should make the clicking sound any time the car is on, and the cluch pedal is released/depressed.
Try it with the car in neutral and the e-brake up.
Old Dec 26, 2001 | 02:19 PM
Choopi's Avatar
I have the same problem.. IT doesn't happen when it is in gear.. Only when it is cold outside, OR when I start the car in the morning. I am fairly worried myself.. It doesn't really make a sound, it is more of a feeling.. Kinda like the clutch is grabbing right at the end.. (I have 9000 miles on mine, clutch isn't burnt) Thanks Random.. I am sure you can advise.. smile.gif
Matt
Old Dec 27, 2001 | 06:16 AM
ozwald300's Avatar
I just came back from the dealership and they looked at my car and said there is nothing wrong,they said it's the hydrolic fluid in the clutch master cyclinder moving around and when the weather changes you can somtimes hear it.
Old Dec 27, 2001 | 06:49 AM
Uh...how does fluid "click"?
Can you reproduce the sound at will, or is it just a sometimes thing?
