Hyundai Aftermarket
-   HELP Forum (https://www.hyundaiaftermarket.org/forum/help-forum-21/)
-   -   elantra 2002 overheating (https://www.hyundaiaftermarket.org/forum/help-forum-21/elantra-2002-overheating-62557/)
hbtdawgs Jun 25, 2011 01:45 PM
hi my elantra is running hot water is rusty so i flushed it out still running hot heater working when it sits and idles temp is normal but when u drive it over heats any ideas?
Stocker Jun 25, 2011 04:11 PM
The coolant should not be plain water, because it will rust. It should also not be rusty. A thermostat that does not open all the way could cause overheating while driving. Pull the thermostat and check it. Or heck, they're cheap and if it's the original your thermostat is old, just get a new one and see if that was it.
If the coolant is actually oily instead of rusty (looks like coffee) then you may have a blown head gasket.
Moved to the appropriate section.
hbtdawgs Jun 25, 2011 07:34 PM
CHANGED the thermostat and that did it thanks for the help.
Stocker Jun 25, 2011 08:53 PM
Hey I'm happy you got it going. Do keep an eye on that coolant color.
If you are responding to the last post in a thread, please use the Add Reply or Fast Reply buttons instead of quoting the entire previous post.
pas1216 Jun 25, 2011 08:55 PM
Glad to hear it was something simple and cheap!
BTW - Why do you guys not like us quoting posts? Just wondering....
WytchDctr Jun 25, 2011 09:24 PM
It is sort of weird if the very next post is quoting the post above it. It only annoys me when people quote a long string of pictures... I JUST SAW THEM?!@?!?@!?@!!!@?!?@!@ :BangHead:
hbtdawgs Jun 26, 2011 02:36 PM
well this morning i found a leak around thermostat housing tried to tighten the cover an heard a crack any ideas where i can get the housing with out going to dealer?
pas1216 Jun 26, 2011 05:25 PM
junkyard, just call around to a few of your local yards. I'm sure they would have one and it shouldn't be any more than $20 bucks
Stocker Jun 26, 2011 08:39 PM
+1 to be a long term owner of a decade-plus old car, get to know the local junkyards.
