Cylinder no.2 misfire CEL
I have a 2001 Hyundai Tiburon w/ 130,000 miles on engine that's throwing a CEL cylinder number 2 misfire
I have replaced #2 fuel injector, ignition coil, and checked the spark plugs after resetting the ECU the CEL comes on again after an hour or so of relentless driving examples: when depressing gas pedal when going up slight inclines I can trigger the cel by giving it a lot of gas and it gives up and goes into limp mode again or on the highway constantly at 65 MPH now it starts to sputter out the exhaust ( a spitting sound ) and the CEL comes on again putting it into limp mode an d it runs fine like that. What could this be? Thanks |
I also replaced the timing belt a 1,000 miles ago
Last misfire episode I had was a bad spark plug wire.
Have you moved the spark plugs and plug wire to a different location to see if it follows to the next cylinder? That would be the easiest check first.
The wires are location-specific, can't swap em around without a second set. Usually my car is reliable for long enough that when wires are suspected they are also old, and I just change them out with new.
I replaced the spark plug wires and now there is no misfire.:happyanim:
I LOVE when that happens. :beercheers:
misfire has returned could oxygen sensor cause this? I suspect a burnt valve, car emitting black smoke as well sometimes. Picking up a low mileage cylinder head from a local junkyard :beercheers:
if you are getting black smoke, it's gas and your tuning is off. A bad oxygen sensor might cause that. Get a code reader on it, and see what it says. Better yet, step up your coder reader to mid-grade, and see what the O2 sensor is saying in real time and check out your fuel trims.
| All times are GMT -6. The time now is 09:18 AM. |
