Check Engine Codes
CEL codes
Standard OBD-II codes starting with "P" P0000 No fault found ?? P0001 Fuel volume regulator control ?? circuit open Wiring, regulator control solenoid P0002 Fuel volume regulator control ?? circuit range/performance Wiring, regulator control solenoid P0003 Fuel volume regulator control ?? circuit low Wiring short to ground, regulator control solenoid P0004 Fuel volume regulator control ?? circuit high Wiring open circuit/short to positive, regulator control solenoid P0005 Fuel shut-off valve control ?? circuit open Wiring open circuit, fuel shut-off valve P0006 Fuel shut-off valve control ?? circuit low Wiring short to ground, fuel shut-off valve P0007 Fuel shut-off valve control ?? circuit high Wiring short to positive, fuel shut-off valve P0008 Engine position system, bank 1 ?? performance Mechanical fault P0009 Engine position system, bank 2 ?? performance Mechanical fault P0010 Camshaft position (CMP) actuator, intake/left/front, bank 1 ?? circuit malfunction Wiring, CMP actuator, ECM P0011 Camshaft position (CMP), intake/left/front, bank 1 ?? timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0012 Camshaft position (CMP), intake/left/front, bank 1 ?? timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0013 Camshaft position (CMP) actuator, intake/left/front, bank 1 ?? circuit malfunction Wiring, CMP actuator, ECM P0014 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 ?? timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0015 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 ?? timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0016 Crankshaft position/camshaft position, bank 1 sensor A ?? correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0017 Crankshaft position/camshaft position, bank 1 sensor B ?? correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0018 Crankshaft position/camshaft position, bank 2 sensor A ?? correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0019 Crankshaft position/camshaft position, bank 2 sensor B ?? correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0020 Camshaft position (CMP) actuator, intake/left/front, bank 2 ?? circuit malfunction Wiring, CMP actuator, ECM P0021 Camshaft position (CMP), intake/left/front, bank 2 ?? timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0022 Camshaft position (CMP), intake/left/front, bank 2 ?? timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0023 Camshaft position (CMP) actuator, exhaust/right/rear, bank 2 ?? circuit malfunction Wiring, CMP actuator, ECM P0024 Camshaft position (CMP), exhaust/right/rear, bank 2 ?? timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0025 Camshaft position (CMP), exhaust/right/rear, bank 2 ?? timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0026 Intake valve control solenoid circuit, bank 1 ?? range/performance Wiring, intake valve control solenoid P0027 Exhaust valve control solenoid circuit, bank 1 ?? range/performance Wiring, exhaust valve control solenoid P0028 Intake valve control solenoid circuit, bank 2 ?? range/performance Wiring, intake valve control solenoid P0029 Exhaust valve control solenoid circuit, bank 2 ?? range/performance Wiring, exhaust valve control solenoid P0030 Heated oxygen sensor (HO2S) 1, bank 1, heater control ?? circuit malfunction Wiring, HO2S, ECM P0031 Heated oxygen sensor (HO2S) 1, bank 1, heater control ?? circuit low Wiring short to ground, HO2S, ECM P0032 Heated oxygen sensor (HO2S) 1, bank 1, heater control ?? circuit high Wiring short to positive, HO2S, ECM P0033 Turbocharger (TC) wastegate regulating valve ?? circuit malfunction Wiring, TC wastegate regulating valve, ECM P0034 Turbocharger (TC) wastegate regulating valve ?? circuit low Wiring short to ground, TC wastegate regulating valve, ECM P0035 Turbocharger (TC) wastegate regulating valve ?? circuit high Wiring short to positive, TC wastegate regulating valve, ECM P0036 Heated oxygen sensor (HO2S) 2, bank 1, heater control ?? circuit malfunction Wiring, HO2S, ECM P0037 Heated oxygen sensor (HO2S) 2, bank 1, heater control ?? circuit low Wiring short to ground, HO2S, ECM P0038 Heated oxygen sensor (HO2S) 2, bank 1, heater control ?? circuit high Wiring short to positive, HO2S, ECM P0039 Turbo/super charger bypass valve, control circuit?? range/performance Wiring, bypass valve P0040 Oxygen sensor signals swapped, bank 1 sensor 1/bank 2 sensor 1 Wiring P0041 Oxygen sensor signals swapped, bank 1 sensor 2/bank 2 sensor 2 Wiring P0042 Heated oxygen sensor (HO2S) 3, bank 1, heater control ?? circuit malfunction Wiring, HO2S, ECM P0043 Heated oxygen sensor (HO2S) 3, bank 1, heater control ?? circuit low Wiring short to ground, HO2S, ECM P0044 Heated oxygen sensor (HO2S) 3, bank 1, heater control ?? circuit high Wiring short to positive, HO2S, ECM P0045 Turbo/super charger boost control solenoid ?? circuit open Wiring, boost control solenoid P0046 Turbo/super charger boost control solenoid ?? circuit range/performance Wiring, boost control solenoid, mechanical fault P0047 Turbo/super charger boost control solenoid ?? circuit low Wiring short to ground, boost control solenoid P0048 Turbo/super charger boost control solenoid ?? circuit high Wiring short to positive, boost control solenoid P0049 Turbo/super charger turbine ?? over-speed Mechanical fault P0050 Heated oxygen sensor (HO2S) 1, bank 2, heater control ?? circuit malfunction Wiring, HO2S, ECM P0051 Heated oxygen sensor (HO2S) 1, bank 2, heater control ?? circuit low Wiring short to ground, HO2S, ECM P0052 Heated oxygen sensor (HO2S) 1, bank 2, heater control ?? circuit high Wiring short to positive, HO2S, ECM P0053 Heated oxygen sensor (HO2S), bank 1, sensor 1 ?? heater resistance Wiring, HO2S P0054 Heated oxygen sensor (HO2S), bank 1, sensor 2 ?? heater resistance Wiring, HO2S P0055 Heated oxygen sensor (HO2S), bank 1, sensor 3 ?? heater resistance Wiring, HO2S P0056 Heated oxygen sensor (HO2S) 2, bank 2, heater control ?? circuit malfunction Wiring, HO2S, ECM P0057 Heated oxygen sensor (HO2S) 2, bank 2, heater control ?? heater circuit low Wiring short to ground, HO2S, ECM P0058 Heated oxygen sensor (HO2S) 2, bank 2, heater control ?? circuit high Wiring short to positive, HO2S, ECM P0059 Heated oxygen sensor (HO2S), bank 2, sensor 1 ?? heater resistance Wiring, HO2S P0060 Heated oxygen sensor (HO2S), bank 2, sensor 2 ?? heater resistance Wiring, HO2S P0061 Heated oxygen sensor (HO2S), bank 2, sensor 3 ?? heater resistance Wiring, HO2S P0062 Heated oxygen sensor (HO2S) 3, bank 2, heater control ?? circuit malfunction Wiring, HO2S, ECM P0063 Heated oxygen sensor (HO2S) 3, bank 2, heater control ?? circuit low Wiring short to ground, HO2S, ECM P0064 Heated oxygen sensor (HO2S) 3, bank 2, heater control ?? circuit high Wiring short to positive, HO2S, ECM P0065 Air assisted injector ?? range/performance problem Air assisted injector P0066 Air assisted injector ?? circuit malfunction/circuit low Wiring short to ground, air assisted injector, ECM P0067 Air assisted injector ?? circuit high Wiring short to positive, air assisted injector, ECM P0068 Manifold pressure (MAP) sensor/Mass air flow (MAF) sensor ?? throttle position correlation Wiring, MAP sensor, MAF sensor, mechanical fault P0069 Manifold pressure (MAP) sensor ?? barometric pressure correlation MAF sensor, mechanical fault P0070 Outside air temperature sensor ?? circuit malfunction Wiring, outside air temperature sensor, ECM P0071 Outside air temperature sensor ?? range/performance problem Outside air temperature sensor P0072 Outside air temperature sensor ?? low input Wiring, short to ground, outside air temperature sensor, ECM P0073 Outside air temperature sensor ?? high input Wiring, short to positive, outside air temperature sensor, ECM P0074 Outside air temperature sensor ?? circuit intermittent Wiring, poor connection, outside air temperature sensor, ECM P0075 Intake valve control solenoid, bank 1 ?? circuit malfunction Wiring, intake valve control solenoid, ECM P0076 Intake valve control solenoid, bank 1 ?? circuit low Wiring short to ground, intake valve control solenoid, ECM P0077 Intake valve control solenoid, bank 1 ?? circuit high Wiring short to positive, intake valve control solenoid, ECM P0078 Exhaust valve control solenoid, bank 1 ?? circuit malfunction Wiring, exhaust valve control solenoid, ECM P0079 Exhaust valve control solenoid, bank 1 ?? circuit low Wiring short to ground, exhaust valve control solenoid, ECM P0080 Exhaust valve control solenoid, bank 1 ?? circuit high Wiring short to positive, exhaust valve control solenoid, ECM P0081 Intake valve control solenoid, bank 2 ?? circuit malfunction Wiring, intake valve control solenoid, ECM P0082 Intake valve control solenoid, bank 2 ?? circuit low Wiring short to ground, intake valve control solenoid, ECM P0083 Intake valve control solenoid, bank 2 ?? circuit high Wiring short to positive, intake valve control solenoid, ECM P0084 Exhaust valve control solenoid, bank 2 ?? circuit malfunction Wiring, exhaust valve control solenoid, ECM P0085 Exhaust valve control solenoid, bank 2 ?? circuit low Wiring short to ground, exhaust valve control solenoid, ECM P0086 Exhaust valve control solenoid, bank 2 ?? circuit high Wiring short to positive, exhaust valve control solenoid, ECM P0087 Fuel rail/system pressure ?? too low Fuel pump, fuel pressure regulator, fuel supply pipe blockage, mechanical fault P0088 Fuel rail/system pressure ?? too high Fuel pump, fuel pressure regulator, fuel return pipe blockage, mechanical fault P0089 Fuel pressure regulator ?? performance problem Fuel pressure regulator, mechanical fault P0090 Fuel metering solenoid ?? open circuit Wiring open circuit, fuel metering solenoid, ECM P0091 Fuel metering solenoid ?? short to ground Wiring short to ground, fuel metering solenoid, ECM P0092 Fuel metering solenoid ?? short to positive Wiring short to positive, fuel metering solenoid, ECM P0093 Fuel system leak detected ?? large leak Wiring, fuel pressure sensor, mechanical fault P0094 Fuel system leak detected ?? small leak Wiring, fuel pressure sensor, mechanical fault P0095 Intake air temperature (IAT) sensor 2 ?? circuit malfunction Wiring, poor connection, IAT sensor, ECM P0096 Intake air temperature (IAT) sensor 2 ?? circuit range/performance Wiring, poor connection, IAT sensor, ECM 37 P0097 Intake air temperature (IAT) sensor 2 ?? circuit low input Wiring short to ground, IAT sensor, ECM P0098 Intake air temperature (IAT) sensor 2 ?? circuit high input Wiring short to positive, IAT sensor, ECM P0099 Intake air temperature (IAT) sensor 2 ?? circuit intermittent/erratic Wiring, poor connection, IAT sensor, ECM P0100 Mass air flow (MAF) sensor/volume air flow (VAF) sensor ?? circuit malfunction Wiring, MAF/VAF sensor, ECM P0101 Mass air flow (MAF) sensor/volume air flow (VAF) sensor ?? range/performance problem Intake leak/blockage, MAF/VAF sensor P0102 Mass air flow (MAF) sensor/volume air flow (VAF) sensor ?? low input Wiring short to ground, MAF/VAF sensor, ECM P0103 Mass air flow (MAF) sensor/volume air flow (VAF) sensor ?? high input Wiring short to positive, MAF/VAF sensor, ECM P0104 Mass air flow (MAF) sensor/volume air flow (VAF) sensor ?? circuit intermittent Wiring, poor connection, MAF/VAF sensor, ECM P0105 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor ?? circuit malfunction Wiring, MAP sensor, BARO sensor, ECM P0106 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor ?? range/performance problem Intake/exhaust leak, wiring, MAP sensor, BARO sensor P0107 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor ?? low input Wiring short to ground, MAP sensor, BARO sensor, ECM P0108 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor ?? high input Wiring short to positive, MAP sensor, BARO sensor, ECM P0109 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor ?? circuit intermittent Wiring, poor connection, MAP sensor, BARO sensor, ECM P0110 Intake air temperature (IAT) sensor ?? circuit malfunction Wiring, IAT sensor, ECM P0111 Intake air temperature (IAT) sensor ?? range/performance problem IAT sensor P0112 Intake air temperature (IAT) sensor ?? low input Wiring short to ground, IAT sensor, ECM P0113 Intake air temperature (IAT) sensor ?? high input Wiring open circuit/short to positive, ground wire defective,IAT sensor, ECM P0114 Intake air temperature (IAT) sensor ?? circuit intermittent Wiring, poor connection, IAT sensor, ECM P0115 Engine coolant temperature (ECT) sensor ?? circuit malfunction Wiring, ECT sensor, ECM P0116 Engine coolant temperature (ECT) sensor ?? range/performance problem Coolant thermostat, poor connection, wiring, ECT sensor P0117 Engine coolant temperature (ECT) sensor ?? low input Coolant thermostat, wiring short to ground, ECT sensor P0118 Engine coolant temperature (ECT) sensor ?? high input Coolant thermostat, wiring open circuit/short to positive, ground wire defective, ECT sensor P0119 Engine coolant temperature (ECT) sensor ?? circuit intermittent Wiring, poor connection, ECT sensor, ECM P0120 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A ?? circuit malfunction Wiring,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A ?? circuit malfunction Wiring,TP/APP switch, ECM P0121 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A ?? range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch A/accelerator pedal position (APP) switch A ?? range/performance problem Accelerator cable adjustment, TP/APP switch P0122 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A ?? low input Wiring short to ground,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A ?? low input Wiring short to ground,TP/APP switch, ECM P0123 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A ?? high input Wiring short to positive,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A ?? high input Wiring short to positive,TP/APP switch, ECM P0124 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A ?? circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A ?? circuit intermittent Wiring, poor connection, TP/APP switch, ECM P0125 Insufficient coolant temperature for closed loop fuel control Wiring, cooling system, coolant thermostat, ECT sensor P0126 Insufficient coolant temperature for stable operation Wiring, cooling system, coolant thermostat, ECT sensor P0127 Intake air temperature ?? too high Wiring short to ground, IAT sensor 2, mechanical fault, ECM P0128 Coolant thermostat ?? coolant temp below thermostat regulating temperature Mechanical fault P0129 Barometric pressure ?? too low Wiring, BARO sensor, mechanical fault P0130 Heated oxygen sensor (HO2S) 1, bank 1 ?? circuit malfunction Heating inoperative, poor connection, wiring, HO2S Oxygen sensor (O2S) 1, bank 1 ?? circuit malfunction Wiring, O2S, ECM P0131 Heated oxygen sensor (HO2S) 1, bank 1 ?? low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 1, bank 1 ?? low voltage Exhaust leak,wiring short to ground, O2S, ECM P0132 Heated oxygen sensor (HO2S) 1, bank 1 ?? high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 1, bank 1 ?? high voltage Wiring short to positive, O2S, ECM P0133 Heated oxygen sensor (HO2S) 1, bank 1 ?? slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 1, bank 1 ?? slow response Wiring, O2S P0134 Heated oxygen sensor (HO2S) 1, bank 1 ?? no acitivty detected Wiring open circuit, heating inoperative, HO2S Oxygen sensor (O2S) 1, bank 1 ?? no activity detected Wiring, O2S P0135 Heated oxygen sensor (HO2S) 1, bank 1, heater control ?? circuit malfunction Fuse, wiring, HO2S, ECM P0136 Heated oxygen sensor (HO2S) 2, bank 1 ?? circuit malfunction Heating inoperative, wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 ?? circuit malfunction Wiring, O2S, ECM P0137 Heated oxygen sensor (HO2S) 2, bank 1 ?? low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 ?? low voltage Exhaust leak,wiring short to ground, O2S, ECM P0138 Heated oxygen sensor (HO2S) 2, bank 1 ?? high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 ?? high voltage Wiring short to positive, O2S, ECM P0139 Heated oxygen sensor (HO2S) 2, bank 1 ?? slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 2, bank 1 ?? slow response Wiring, O2S P0140 Heated oxygen sensor (HO2S) 2, bank 1 ?? no acitivty detected Wiring, heating inoperative, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 ?? no activity detected Wiring, O2S, ECM P0141 Heated oxygen sensor (HO2S) 2, bank 1, heater control ?? circuit malfunction Wiring, HO2S, ECM P0142 Heated oxygen sensor (HO2S) 3, bank 1 ?? circuit malfunction Wiring, HO2S, ECM P0143 Heated oxygen sensor (HO2S) 3, bank 1 ?? low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 ?? low voltage Exhaust leak,wiring short to ground, O2S, ECM P0144 Heated oxygen sensor (HO2S) 3, bank 1 ?? high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 ?? high voltage Wiring short to positive, O2S, ECM P0145 Heated oxygen sensor (HO2S) 3, bank 1 ?? slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 3, bank 1 ?? slow response Wiring, O2S P0146 Heated oxygen sensor (HO2S) 3, bank 1 ?? no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 ?? no activity detected Wiring, O2S, ECM P0147 Heated oxygen sensor (HO2S) 3, bank 1, heater control ?? circuit malfunction Wiring, HO2S, ECM P0148 Fuel delivery error Fuel pump/fuel injection pump P0149 Fuel timing error Fuel pump/fuel injection pump P0150 Heated oxygen sensor (HO2S) 1, bank 2 ?? circuit malfunction Wiring, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 ?? circuit malfunction Wiring, O2S, ECM P0151 Heated oxygen sensor (HO2S) 1, bank 2 ?? low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 ?? low voltage Exhaust leak,wiring short to ground, O2S, ECM P0152 Heated oxygen sensor (HO2S) 1, bank 2 ?? high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 ?? high voltage Wiring short to positive, O2S, ECM P0153 Heated oxygen sensor (HO2S) 1, bank 2 ?? slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 1, bank 2 ?? slow response Wiring, O2S P0154 Heated oxygen sensor (HO2S) 1, bank 2 ?? no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 ?? no activity detected Wiring, O2S, ECM P0155 Heated oxygen sensor (HO2S) 1, bank 2, heater control ?? circuit malfunction Wiring, HO2S, ECM P0156 Heated oxygen sensor (HO2S) 2, bank 2 ?? circuit malfunction Heating inoperative, wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 ?? circuit malfunction Wiring, O2S, ECM P0157 Heated oxygen sensor (HO2S) 2, bank 2 ?? low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 ?? low voltage Exhaust leak,wiring short to ground, O2S, ECM P0158 Heated oxygen sensor (HO2S) 2, bank 2 ?? high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 ?? high voltage Wiring short to positive, O2S, ECM P0159 Heated oxygen sensor (HO2S) 2, bank 2 ?? slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 2, bank 2 ?? slow response Wiring, O2S P0160 Heated oxygen sensor (HO2S) 2, bank 2 ?? no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 ?? no activity detected Wiring, O2S, ECM P0161 Heated oxygen sensor (HO2S) 2, bank 2, heater control ?? circuit malfunction Wiring, HO2S, ECM P0162 Heated oxygen sensor (HO2S) 3, bank 2 ?? circuit malfunction Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 ?? circuit malfunction Wiring, O2S, ECM P0163 Heated oxygen sensor (HO2S) 3, bank 2 ?? low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 ?? low voltage Exhaust leak, wiring short to ground, O2S, ECM P0164 Heated oxygen sensor (HO2S) 3, bank 2 ?? high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 ?? high voltage Wiring short to positive, O2S, ECM P0165 Heated oxygen sensor (HO2S) 3, bank 2 ?? slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 3, bank 2 ?? slow response Wiring, O2S P0166 Heated oxygen sensor (HO2S) 3, bank 2 ?? no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 ?? no activity detected Wiring, O2S, ECM P0167 Heated oxygen sensor (HO2S) 3, bank 2, heater control ?? circuit malfunction Wiring, HO2S, ECM P0168 Fuel temperature ?? too high Wiring, fuel temperature sensor, mechanical fault P0169 Incorrect fuel composition Wiring, fuel temperature sensor, mechanical fault P0170 Fuel trim (FT), bank 1 ?? malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S P0171 System too lean, bank 1 Intake/exhaust leak, AIR system, MAF/VAF sensor, fuel pressure/pump, injector(s), HO2S P0172 System too rich, bank 1 Intake blocked, EVAP canister purge valve, fuel pressure,EGR system, injector(s), HO2S P0173 Fuel trim (FT), bank 2 ?? malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S P0174 System too lean, bank 2 Intake/exhaust leak, fuel pressure/pump, injector(s), AIR system, hose connection(s) P0175 System too rich, bank 2 Intake blocked, EVAP canister purge valve, fuel pressure, EGR system, injector(s), HO2S P0176 Fuel composition sensor ?? circuit malfunction Wiring, fuel composition sensor, ECM P0177 Fuel composition sensor ?? range/performance problem Fuel composition sensor P0178 Fuel composition sensor ?? low input Wiring short to ground, fuel composition sensor, ECM P0179 Fuel composition sensor ?? high input Wiring short to positive, fuel composition sensor, ECM P0180 Fuel temperature sensor A ?? circuit malfunction Wiring, fuel temperature sensor, ECM P0181 Fuel temperature sensor A ?? range/performance problem Fuel temperature sensor P0182 Fuel temperature sensor A ?? low input Wiring short to ground, fuel temperature sensor, ECM P0183 Fuel temperature sensor A ?? high input Wiring short to positive, fuel temperature sensor, ECM P0184 Fuel temperature sensor A ?? circuit intermittent Wiring, poor connection, fuel temperature sensor, ECM P0185 Fuel temperature sensor B ?? circuit malfunction Wiring, fuel temperature sensor, ECM P0186 Fuel temperature sensor B ?? range/performance problem Fuel temperature sensor P0187 Fuel temperature sensor B ?? low input Wiring short to ground, fuel temperature sensor, ECM P0188 Fuel temperature sensor B ?? high input Wiring short to positive, fuel temperature sensor, ECM P0189 Fuel temperature sensor B ?? circuit intermittent Wiring, poor connection, fuel temperature sensor, ECM P0190 Fuel rail pressure (FRP) sensor ?? circuit malfunction Wiring, fuel rail pressure sensor, ECM P0191 Fuel rail pressure (FRP) sensor ?? range/performance problem Wiring, FRP sensor P0192 Fuel rail pressure (FRP) sensor ?? low input Wiring short to ground, FRP sensor P0193 Fuel rail pressure (FRP) sensor ?? high input Wiring short to positive, FRP sensor P0194 Fuel rail pressure (FRP) sensor ?? circuit intermittent Wiring, poor connection, FRP sensor P0195 Engine oil temperature (EOT) sensor ?? circuit malfunction Wiring, EOT sensor, ECM P0196 Engine oil temperature (EOT) sensor ?? range/performance problem EOT sensor P0197 Engine oil temperature (EOT) sensor ?? low input Wiring short to ground, EOT sensor P0198 Engine oil temperature (EOT)) sensor ?? high input Wiring short to positive, EOT sensor P0199 Engine oil temperature (EOT) sensor ?? circuit intermittent Wiring, poor connection, EOT sensor, ECM P0200 Injector ?? circuit malfunction Wiring, injector, ECM P0201 Injector 1 ?? circuit malfunction Wiring, injector, ECM P0202 Injector 2 ?? circuit malfunction Wiring, injector, ECM P0203 Injector 3 ?? circuit malfunction Wiring, injector, ECM P0204 Injector 4 ?? circuit malfunction Wiring, injector, ECM P0205 Injector 5 ?? circuit malfunction Wiring, injector, ECM P0206 Injector 6 ?? circuit malfunction Wiring, injector, ECM P0207 Injector 7 ?? circuit malfunction Wiring, injector, ECM P0208 Injector 8 ?? circuit malfunction Wiring, injector, ECM P0209 Injector 9 ?? circuit malfunction Wiring, injector, ECM P0210 Injector 10 ?? circuit malfunction Wiring, injector, ECM P0211 Injector 11 ?? circuit malfunction Wiring, injector, ECM P0212 Injector 12 ?? circuit malfunction Wiring, injector, ECM P0213 Cold start injector 1 ?? circuit malfunction Wiring, cold start injector, ECM P0214 Cold start injector 2 ?? circuit malfunction Wiring, cold start injector, ECM P0215 Fuel shut-off solenoid ?? circuit malfunction Wiring, fuel shut-off solenoid, ECM P0216 Fuel injection timing control ?? circuit malfunction Wiring, fuel injection timing control solenoid, ECM P0217 Engine over temperature condition Wiring, cooling system, coolant thermostat, ECT sensor P0218 Transmission over temperature condition Wiring, TFT sensor, ECM P0219 Engine over speed condition Incorrect gear change P0220 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B ?? circuit malfunction Wiring, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B ?? circuit malfunction Wiring, TP/APP switch, ECM P0221 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B ?? range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch B/accelerator pedal position (APP) switch B ?? range/performance problem Accelerator cable adjustment, TP/APP switch P0222 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B ?? low input Wiring short to ground, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B ?? low input Wiring short to ground, TP/APP switch, ECM P0223 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B ?? high input Wiring short to positive, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B ?? high input Wiring short to positive, TP/APP switch, ECM P0224 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B ?? circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B ?? circuit intermittent Wiring, poor connection, TP/APP switch, ECM P0225 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C ?? circuit malfunction Wiring, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C ?? circuit malfunction Wiring, TP/APP switch, ECM P0226 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C ?? range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch C/accelerator pedal position (APP) switch C ?? range/performance problem Accelerator cable adjustment, TP/APP switch P0227 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C ?? low input Wiring short to ground, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C ?? low input Wiring short to ground, TP/APP switch, ECM P0228 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C ?? high input Wiring short to positive, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C ?? high input Wiring short to positive, TP/APP switch, ECM P0229 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C ?? circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C ?? circuit intermittent Wiring, poor connection, TP/APP switch, ECM P0230 Fuel pump relay ?? circuit malfunction Wiring, fuel pump relay, ECM P0231 Fuel pump relay ?? circuit low Wiring short to ground, fuel pump relay, ECM P0232 Fuel pump relay ?? circuit high Wiring short to positive, fuel pump relay, ECM P0233 Fuel pump relay ?? circuit intermittent Wiring, poor connection, fuel pump relay, ECM P0234 Engine boost condition ?? limit exceeded Hose connection(s), wiring, TC wastergate regulating valve, TC wastegate P0235 Engine boost condition ?? limit not reached Hose connection(s), wiring, TC wastergate regulating valve, TC wastegate, TC P0236 Manifold absolute pressure (MAP) sensor A, TC system ?? range/performance problem Intake/exhaust leak, hose connection(s), MAP sensor P0237 Manifold absolute pressure (MAP) sensor A, TC system ?? low input Wiring short to ground, MAP sensor, ECM P0238 Manifold absolute pressure (MAP) sensor A, TC system ?? high input Wiring short to positive, MAP sensor, ECM P0239 Manifold absolute pressure (MAP) sensor B, TC system ?? circuit malfunction Wiring, MAP sensor, ECM P0240 Manifold absolute pressure (MAP) sensor B, TC system ?? range/performance problem Intake/exhaust leak, hose connection(s), MAP sensor P0241 Manifold absolute pressure (MAP) sensor B, TC system ?? low input Wiring short to ground, MAP sensor, ECM P0242 Manifold absolute pressure (MAP) sensor B, TC system ?? high input Wiring short to positive, MAP sensor, ECM P0243 Turbocharger (TC) wastegate regulating valve A ?? circuit malfunction Wiring, TC wastegate regulating valve, ECM P0244 Turbocharger (TC) wastegate regulating valve A ?? range/performance problem TC wastegate regulating valve P0245 Turbocharger (TC) wastegate regulating valve A ?? circuit low Wiring short to ground, TC wastegate regulating valve, ECM P0246 Turbocharger (TC) wastegate regulating valve A ?? circuit high Wiring short to positive, TC wastegate regulating valve, ECM P0247 Turbocharger (TC) wastegate regulating valve B ?? circuit malfunction Wiring, TC wastegate regulating valve, ECM P0248 Turbocharger (TC) wastegate regulating valve B ?? range/performance problem TC wastegate regulating valve P0249 Turbocharger (TC) wastegate regulating valve B ?? circuit low Wiring short to ground, TC wastegate regulating valve, ECM P0250 Turbocharger (TC) wastegate regulating valve B ?? circuit high Wiring short to positive, TC wastegate regulating valve, ECM P0251 Injection pump A, rotor/cam ?? circuit malfunction Wiring, injection pump, ECM P0252 Injection pump A, rotor/cam ?? range/performance problem Injection pump P0253 Injection pump A, rotor/cam ?? circuit low Wiring short to ground, injection pump, ECM P0254 Injection pump A, rotor/cam ?? circuit high Wiring short to positive, injection pump, ECM P0255 Injection pump A, rotor/cam ?? circuit intermittent Wiring, poor connection, injection pump, ECM P0256 Injection pump B, rotor/cam ?? circuit malfunction Wiring, injection pump, ECM P0257 Injection pump B, rotor/cam ?? range/performance problem Injection pump P0258 Injection pump B, rotor/cam ?? circuit low Wiring short to ground, injection pump, ECM P0259 Injection pump B, rotor/cam ?? circuit high Wiring short to positive, injection pump, ECM P0260 Injection pump B, rotor/cam ?? circuit intermittent Wiring, poor connection, injection pump, ECM P0261 Injector 1 ?? circuit low Wiring short to ground, injector, ECM P0262 Injector 1 ?? circuit high Wiring short to positive, injector, ECM P0263 Cylinder 1 ?? contribution/balance fault Wiring, fuel system, ECM P0264 Injector 2 ?? circuit low Wiring short to ground, injector, ECM P0265 Injector 2 ?? circuit high Wiring short to positive, injector, ECM P0266 Cylinder 2 ?? contribution/balance fault Wiring, fuel system, ECM P0267 Injector 3 ?? circuit low Wiring short to ground, injector, ECM P0268 Injector 3 ?? circuit high Wiring short to positive, injector, ECM P0269 Cylinder 3 ?? contribution/balance fault Wiring, fuel system, ECM P0270 Injector 4 ?? circuit low Wiring short to ground, injector, ECM P0271 Injector 4 ?? circuit high Wiring short to positive, injector, ECM P0272 Cylinder 4 ?? contribution/balance fault Wiring, fuel system, ECM P0273 Injector 5 ?? circuit low Wiring short to ground, injector, ECM P0274 Injector 5 ?? circuit high Wiring short to positive, injector, ECM P0275 Cylinder 5 ?? contribution/balance fault Wiring, fuel system, ECM P0276 Injector 6 ?? circuit low Wiring short to ground, injector, ECM P0277 Injector 6 ?? circuit high Wiring short to positive, injector, ECM P0278 Cylinder 6 ?? contribution/balance fault Wiring, fuel system, ECM P0279 Injector 7 ?? circuit low Wiring short to ground, injector, ECM P0280 Injector 7 ?? circuit high Wiring short to positive, injector, ECM P0281 Cylinder 7 ?? contribution/balance fault Wiring, fuel system, ECM P0282 Injector 8 ?? circuit low Wiring short to ground, injector, ECM P0283 Injector 8 ?? circuit high Wiring short to positive, injector, ECM P0284 Cylinder 8 ?? contribution/balance fault Wiring, fuel system, ECM P0285 Injector 9 ?? circuit low Wiring short to ground, injector, ECM P0286 Injector 9 ?? circuit high Wiring short to positive, injector, ECM P0287 Cylinder 9 ?? contribution/balance fault Wiring, fuel system, ECM P0288 Injector 10 ?? circuit low Wiring short to ground, injector, ECM P0289 Injector 10 ?? circuit high Wiring short to positive, injector, ECM P0290 Cylinder 10 ?? contribution/balance fault Wiring, fuel system, ECM P0291 Injector 11 ?? circuit low Wiring short to ground, injector, ECM P0292 Injector 11 ?? circuit high Wiring short to positive, injector, ECM P0293 Cylinder 11 ?? contribution/balance fault Wiring, fuel system, ECM P0294 Injector 12 ?? circuit low Wiring short to ground, injector, ECM P0295 Injector 12 ?? circuit high Wiring short to positive, injector, ECM P0296 Cylinder 12 ?? contribution/balance fault Wiring, fuel system, ECM P0297 Vehicle over-speed condition Wiring, VSS, mechanical fault P0298 Engine oil temperature ?? too high Wiring, EOT sensor, mechanical fault P0299 Turbo/super charger ?? low boost Mechanical fault P0300 Random/multiple cylinder(s) ?? misfire detected Spark plug(s), HT lead(s), injector(s), ignition coil(s),low compression, wiring P0301 Cylinder 1 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0302 Cylinder 2 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0303 Cylinder 3 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0304 Cylinder 4 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0305 Cylinder 5 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0306 Cylinder 6 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0307 Cylinder 7 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0308 Cylinder 8 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0309 Cylinder 9 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0310 Cylinder 10 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0311 Cylinder 11 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0312 Cylinder 12 ?? misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0313 Misfire detected ?? low fuel level Fuel system, mechanical fault P0314 Single cylinder misfire ?? cylinder not specified Engine mechanical fault, wiring, ignition/fuel system, injector P0315 Crankshaft position system ?? variation not learned Engine mechanical fault, wiring P0316 Misfire dectected during startup ?? first 1000 revolutions Engine mechanical fault, wiring, ignition/fuel system, injector P0317 Rough road hardware not present Wiring, ECM P0318 Rough road sensor signal A ?? circuit malfunction Wiring, rough road sensor A, mechanical fault P0319 Rough road sensor signal B ?? circuit malfunction Wiring, rough road sensor B, mechanical fault P0320 Crankshaft position (CKP) sensor/engine speed (RPM) sensor ?? circuit malfunction WiringCKP/RPM sensor, ECM P0321 Crankshaft position (CKP) sensor/engine speed (RPM) sensor ?? range/performance problem Air gap, metal particle contamination, insecure sensor/rotor, wiring, CKP/RPM sensor P0322 Crankshaft position (CKP) sensor/engine speed (RPM) sensor ?? no signal Wiring, CKP/RPM sensor, ECM P0323 Crankshaft position (CKP) sensor/engine speed (RPM) sensor ?? circuit intermittent Wiring, poor connection, CKP/RPM sensor, ECM P0324 Knock control system error Wiring, poor connection, KS, ECM P0325 Knock sensor (KS) 1, bank 1 ?? circuit malfunction Wiring, poor connection, KS P0326 Knock sensor (KS) 1, bank 1 ?? range/performance problem Wiring, KS incorrectly tightened, KS P0327 Knock sensor (KS) 1, bank 1 ?? low input Insecure KS, poor connection, wiring short to ground,incorrectly tightened, KS, ECM P0328 Knock sensor (KS) 1, bank 1 ?? high input Wiring short to positive, KS incorrectly tightened, KS, ECM P0329 Knock sensor (KS) 1, bank 1 ?? circuit intermittent Wiring, poor connection, KS, ECM P0330 Knock sensor (KS) 2, bank 2 ?? circuit malfunction Wiring, KS, ECM P0331 Knock sensor (KS) 2, bank 2 ?? range/performance problem Wiring, KS incorrectly tightened, KS P0332 Knock sensor (KS) 2, bank 2 ?? low input Insecure KS, poor connection, wiring short to ground,incorrectly tightened, KS, ECM P0333 Knock sensor (KS) 2, bank 2 ?? high input Wiring short to positive, KS incorrectly tightened, KS, ECM P0334 Knock sensor (KS) 2, bank 2 ?? circuit intermittent Wiring, poor connection, KS, ECM P0335 Crankshaft position (CKP) sensor ?? circuit malfunction Wiring, CKP sensor, ECM P0336 Crankshaft position (CKP) sensor ?? range/performance problem Insecure sensor/rotor, air gap, wiring, CKP sensor P0337 Crankshaft position (CKP) sensor ?? low input Wiring short to ground, CKP sensor, ECM P0338 Crankshaft position (CKP) sensor ?? high input Wiring short to positive, CKP sensor, ECM P0339 Crankshaft position (CKP) sensor?? circuit intermittent Wiring, poor connection, CKP sensor, ECM P0340 Camshaft position (CMP) sensor A, bank 1 ?? circuit malfunction Wiring, CMP sensor, ECM P0341 Camshaft position (CMP) sensor A, bank 1 ?? range/performance problem Insecure sensor/rotor, air gap, wiring, CMP sensor P0342 Camshaft position (CMP) sensor A, bank 1 ?? low input Wiring short to ground, CMP sensor, ECM P0343 Camshaft position (CMP) sensor A, bank 1 ?? high input Wiring short to positive, CMP sensor, ECM P0344 Camshaft position (CMP) sensor A, bank 1?? circuit intermittent Wiring, poor connection, CMP sensor, ECM P0345 Camshaft position (CMP) sensor A, bank 2 ?? circuit malfunction Wiring, CMP sensor, ECM P0346 Camshaft position (CMP) sensor A, bank 2 ?? range/performance problem Insecure sensor/rotor, air gap, wiring, CMP sensor P0347 Camshaft position (CMP) sensor A, bank 2 ?? low input Wiring short to ground, CMP sensor, ECM P0348 Camshaft position (CMP) sensor A, bank 2 ?? high input Wiring short to positive, CMP sensor, ECM P0349 Camshaft position (CMP) sensor A, bank 2?? circuit intermittent Wiring, poor connection, CMP sensor, ECM P0350 Ignitiion coil, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0351 Ignitiion coil A, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0352 Ignitiion coil B, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0353 Ignitiion coil C, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0354 Ignitiion coil D, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0355 Ignitiion coil E, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0356 Ignitiion coil F, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0357 Ignitiion coil G, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0358 Ignitiion coil H, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0359 Ignitiion coil I, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0360 Ignitiion coil J, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0361 Ignitiion coil K, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0362 Ignitiion coil L, primary/secordary ?? circuit malfunction Wiring, ignition coil, ECM P0363 Misfire detected ?? fueling disabled Fuel system, mechanical fault P0365 Camshaft position (CMP) sensor B, bank 1 ?? circuit malfunction Wiring, poor connection, CMP sensor, ECM P0366 Camshaft position (CMP) sensor B, bank 1 ?? range/performance problem Wiring, poor connection, CMP sensor P0367 Camshaft position (CMP) sensor B, bank 1 ?? low input Wiring short to ground, CMP sensor, ECM P0368 Camshaft position (CMP) sensor B, bank 1 ?? high input Wiring short to positive, CMP sensor, ECM P0369 Camshaft position (CMP) sensor B, bank 1?? circuit intermittent Wiring, poor connection, ECM P0370 Timing reference, high resolution signal A ?? malfunction Wiring, CKP/RPM/CMP sensor, ECM P0371 Timing reference, high resolution signal A ?? too many pulses Wiring, CKP/RPM/CMP sensor, ECM P0372 Timing reference, high resolution signal A ?? too few pulses Wiring, CKP/RPM/CMP sensor, ECM P0373 Timing reference, high resolution signal A ?? intermittent erratic pulses Wiring, poor connection, CKP/RPM/CMP sensor, ECM P0374 Timing reference, high resolution signal A ?? no pulses Wiring, CKP/RPM/CMP sensor, ECM P0375 Timing reference, high resolution signal B ?? malfunction Wiring, CKP/RPM/CMP sensor, ECM P0376 Timing reference, high resolution signal B ?? too many pulses Wiring, CKP/RPM/CMP sensor, ECM P0377 Timing reference, high resolution signal B ?? too few pulses Wiring, CKP/RPM/CMP sensor, ECM P0378 Timing reference, high resolution signal B ?? intermittent erratic pulses Wiring, poor connection, CKP/RPM/CMP sensor, ECM P0379 Timing reference, high resolution signal B ?? no pulses Wiring, CKP/RPM/CMP sensor, ECM P0380 Glow plugs, circuit A ?? malfunction Wiring, glow plug relay, fuse, glow plugs, ECM P0381 Glow plug warning lamp ?? circuit malfunction Wiring, glow plug warning lamp, ECM P0382 Glow plugs, circuit B ?? malfunction Wiring, glow plug relay, fuse, glow plugs, ECM P0385 Crankshaft position (CKP) sensor B ?? circuit malfunction Wiring, CKP sensor, ECM P0386 Crankshaft position (CKP) sensor B ?? range/performance problem Insecure sensor/rotor, air gap, wiring, CKP sensor P0387 Crankshaft position (CKP) sensor B ?? low input Wiring short to ground, CKP sensor, ECM P0388 Crankshaft position (CKP) sensor B ?? high input Wiring short to positive, CKP sensor, ECM P0389 Crankshaft position (CKP) sensor B ?? circuit intermittent Wiring, poor connection, CKP sensor, ECM P0390 Camshaft position (CMP) sensor B, bank 2 ?? circuit malfunction Wiring, poor connection, CMP sensor, ECM P0391 Camshaft position (CMP) sensor B, bank 2 ?? circuit range/performance problem Wiring, poor connection, CMP sensor P0392 Camshaft position (CMP) sensor B, bank 2 ?? circuit low input Wiring short to ground, CMP sensor, ECM P0393 Camshaft position (CMP) sensor B, bank 2 ?? circuit high input Wiring short to positive, CMP sensor, ECM P0394 Camshaft position (CMP) sensor B, bank 2?? circuit intermittent Wiring, poor connection, ECM P0400 Exhaust gas recirculation (ERG) system ?? flow malfunction Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM P0401 Exhaust gas recirculation (ERG) system ?? insufficient flow detected Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM P0402 Exhaust gas recirculation (ERG) system ?? excessive flow detected Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM P0403 Exhaust gas recirculation (ERG) system ?? circuit malfunction Wiring, EGR solenoid, ECM P0404 Exhaust gas recirculation (ERG) system ?? range/performance problem Hose leak/blockage, wiring, EGR valve/solenoid P0405 Exhaust gas recirculation (ERG) valve position sensor A ?? low input Wiring short to ground, EGR valve position sensor, ECM P0406 Exhaust gas recirculation (ERG) valve position sensor A ?? high input Wiring short to positive, EGR valve position sensor, ECM P0407 Exhaust gas recirculation (ERG) valve position sensor B ?? low input Wiring short to ground, EGR valve position sensor, ECM P0408 Exhaust gas recirculation (ERG) valve position sensor B ?? high input Wiring short to positive, EGR valve position sensor, ECM P0409 Exhaust gas recirculation (ERG) sensor A ?? circuit malfunction Wiring, poor connection, EGR sensor, ECM P0410 Secondary air injection (AIR) system ?? malfunction Wiring, AIR valve, AIR solenoid, ECM P0411 Secondary air injection (AIR) system ?? incorrect flow detected AIR pump, AIR valve, AIR hose(s) P0412 Secondary air injection (AIR) solenoid A ?? circuit malfunction Wiring, AIR solenoid, ECM P0413 Secondary air injection (AIR) solenoid A ?? open circuit Wiring open circuit, AIR solenoid, ECM P0414 Secondary air injection (AIR) solenoid A ?? short circuit Wiring short circuit, AIR solenoid, ECM P0415 Secondary air injection (AIR) solenoid B ?? circuit malfunction Wiring, AIR solenoid, ECM P0416 Secondary air injection (AIR) solenoid B ?? open circuit Wiring open circuit, AIR solenoid, ECM P0417 Secondary air injection (AIR) solenoid B ?? short circuit Wiring short circuit, AIR solenoid, ECM P0418 Secondary air injection (AIR) pump relay A ?? circuit malfunction Wiring, AIR pump relay, ECM P0419 Secondary air injection (AIR) pump relay B ?? circuit malfunction Wiring, AIR pump relay, ECM P0420 Catalytic converter system, bank 1 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0421 Warm up catalytic converter, bank 1 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0422 Main catalytic converter, bank 1 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0423 Heated catalytic converter, bank 1 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0424 Heated catalytic converter, bank 1 ?? temperature below threshold Catalytic converter, wiring, HO2S 2 P0425 Catalytic converter temperature sensor, bank 1 Wiring, poor connection, catalytic converter temperature sensor, ECM P0426 Catalytic converter temperature sensor, bank 1 ?? range/performance Wiring, poor connection, catalytic converter temperature sensor, ECM P0427 Catalytic converter temperature sensor, bank 1 ?? low input Wiring short to ground, catalytic converter temperature sensor, ECM P0428 Catalytic converter temperature sensor, bank 1 ?? high input Wiring short to positive, catalytic converter temperature sensor, ECM P0429 Catalytic converter heater, bank 1 ?? control circuit malfunction Wiring, relay, ECM P0430 Catalytic converter system, bank 2 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0431 Warm up catalytic converter, bank 2 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0432 Main catalytic converter, bank 2 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0433 Heated catalytic converter, bank 2 ?? efficiency below threshold Catalytic converter, wiring, HO2S 2 P0434 Heated catalytic converter, bank 2 ?? temperature below threshold Catalytic converter, wiring, HO2S 2 P0435 Catalytic converter temperature sensor, bank 2 Wiring, poor connection, catalytic converter temperature sensor, ECM P0436 Catalytic converter temperature sensor, bank 2 ?? range/performance Wiring, poor connection, catalytic converter temperature sensor, ECM P0437 Catalytic converter temperature sensor, bank 2 ?? low input Wiring short to ground, catalytic converter temperature sensor, ECM P0438 Catalytic converter temperature sensor, bank 2 ?? high input Wiring short to positive, catalytic converter temperature sensor, ECM P0439 Catalytic converter heater, bank 2 ?? control circuit malfunction Wiring, relay, ECM P0440 Evaporative emission (EVAP) system ?? malfunction Hose connection(s), intake leak, EVAP canister purge valve P0441 Evaporative emission (EVAP) system ?? incorrect flow detected Hose connection(s), intake leak, EVAP canister purge valve P0442 Evaporative emission (EVAP) system ?? small leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve P0443 Evaporative emission (EVAP) canister purge valve ?? circuit malfunction Wiring, EVAP canister purge valve, ECM P0444 Evaporative emission (EVAP) canister purge valve ?? open circuit Wiring open circuit, EVAP canister purge valve, ECM P0445 Evaporative emission (EVAP) canister purge valve ?? short circuit Wiring short circuit, EVAP canister purge valve, ECM P0446 Evaporative emission (EVAP) system, vent control ?? circuit malfunction Wiring, EVAP canister purge valve, ECM P0447 Evaporative emission (EVAP) system, vent control ?? open circuit Wiring open circuit, EVAP canister purge valve, ECM P0448 Evaporative emission (EVAP) system, vent control ?? short circuit Wiring short circuit, EVAP canister purge valve, ECM P0449 Evaporative emission (EVAP) system, vent valve ?? circuit malfunction Wiring, EVAP canister purge valve, ECM P0450 Evaporative emission (EVAP) pressure sensor ?? circuit malfunction Wiring, EVAP pressure sensor, ECM P0451 Evaporative emission (EVAP) pressure sensor ?? range/performance problem EVAP pressure sensor P0452 Evaporative emission (EVAP) pressure sensor ?? low input Wiring short to ground, EVAP pressure sensor, ECM P0453 Evaporative emission (EVAP) pressure sensor ?? high input Wiring short to positive, EVAP pressure sensor, ECM P0454 Evaporative emission (EVAP) pressure sensor ?? circuit intermittent Wiring, poor connection, EVAP pressure sensor, ECM P0455 Evaporative emission (EVAP) system ?? large leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve P0456 Evaporative emission system ?? very small leak detected Mechanical fault, hose connection(s), EVAP pressure sensor P0457 Evaporative emission system ?? leak detected (fuel cap loose/off) Mechanical fault, hose connection(s), EVAP pressure sensor P0458 Evaporative emission system, purge control valve ?? circuit low Wiring short to ground, EVAP valve P0459 Evaporative emission system, purge control valve ?? circuit high Wiring short to positive, EVAP valve P0460 Fuel tank level sensor ?? circuit malfunction Wiring, fuel tank level sensor, ECM P0461 Fuel tank level sensor ?? range/performance problem Wiring, fuel tank level sensor P0462 Fuel tank level sensor ?? low input Wiring short to ground, fuel tank level sensor, ECM P0463 Fuel tank level sensor ?? high input Wiring short to positive, fuel tank level sensor, ECM P0464 Fuel tank level sensor ?? circuit intermittent Wiring, poor connection, fuel tank level sensor, ECM P0465 Evaporative emission (EVAP) canister purge flow sensor ?? circuit malfunction Wiring, EVAP canister purge flow sensor, ECM P0466 Evaporative emission (EVAP) canister purge flow sensor ?? range/performance problem EVAP canister purge flow sensor P0467 Evaporative emission (EVAP) canister purge flow sensor ?? low input Wiring short to ground, EVAP canister purge flow sensor, ECM P0468 Evaporative emission (EVAP) canister purge flow sensor ?? high input Wiring short to positive, EVAP canister purge flow sensor, ECM P0469 Evaporative emission (EVAP) canister purge flow sensor ?? circuit intermittent Wiring, poor connection, EVAP canister purge flow sensor, ECM P0470 Exhaust gas pressure sensor ?? circuit malfunction Wiring, exhaust gas pressure sensor, ECM P0471 Exhaust gas pressure sensor ?? range/performance problem Exhaust gas pressure sensor P0472 Exhaust gas pressure sensor ?? low input Wiring short to ground, exhaust gas pressure sensor, ECM P0473 Exhaust gas pressure sensor ?? high input Wiring short to positive, exhaust gas pressure sensor, ECM P0474 Exhaust gas pressure sensor ?? circuit intermittent Wiring, poor connection, exhaust gas pressure sensor, ECM P0475 Exhaust gas pressure control valve ?? circuit malfunction Wiring, exhaust gas pressure control valve, ECM P0476 Exhaust gas pressure control valve ?? range/performance problem Exhaust gas control valve sensor P0477 Exhaust gas pressure control valve ?? low input Wiring short to ground, exhaust gas control valve sensor, ECM P0478 Exhaust gas pressure control valve ?? high input Wiring short to positive, exhaust gas control valve sensor, ECM P0479 Exhaust gas pressure control valve ?? circuit intermittent Wiring, poor connection, exhaust gas control valve sensor, ECM P0480 Engine coolant blower motor 1 ?? circuit malfunction Wiring, engine coolant blower motor, ECM P0481 Engine coolant blower motor 2 ?? circuit malfunction Wiring, engine coolant blower motor, ECM P0482 Engine coolant blower motor 3 ?? circuit malfunction Wiring, engine coolant blower motor, ECM P0483 Engine coolant blower motor, rationality check ?? malfunction Wiring, engine coolant blower motor, ECM P0484 Engine coolant blower motor ?? circuit over current Wiring, engine coolant blower motor, ECM P0485 Engine coolant blower motor, power/earth ?? circuit malfunction Wiring, engine coolant blower motor, ECM P0486 Exhaust gas recirculation (EGR) valve poistion sensor B ?? circuit malfunction Wiring, poor connection, EGR valve position sensor, ECM P0487 Exhaust gas recirculation (EGR) system, throttle position control ?? circuit malfunction Wiring, poor connection, ECM P0488 Exhaust gas recirculation (EGR) system, throttle position control ?? range/performance Wiring, poor connection, ECM P0489 Exhaust gas recirculation (EGR) system ?? circuit low Wiring short to ground, EGR valve P0490 Exhaust gas recirculation (EGR) system ?? circuit high Wiring short to posistive, EGR valve P0491 Secondary air injection system, bank 1 ?? malfunction Wiring, AIR solenoid, hose connections, mechanical fault P0492 Secondary air injection system, bank 2 ?? malfunction Wiring, AIR solenoid, hose connections, mechanical fault P0493 Fan over-speed (clutch locked) Fan clutch, mechanical fault P0494 Fan speed ?? low Wiring, relay, fan motor, mechanical fault P0495 Fan speed ?? high Wiring, relay, fan motor, mechanical fault P0496 Evaporative emission system ?? high purge flow Wiring, EVAP valve, mechanical fault P0497 Evaporative emission system ?? low purge flow Wiring, EVAP valve, hoses blocked, mechanical fault P0498 Evaporative emission system, vent control ?? circuit low Wiring, short to gound, EVAP valve P0499 Evaporative emission system, vent control ?? circuit high Wiring, short to positive, EVAP valve P0500 Vehicle speed sensor (VSS) ?? circuit malfunction Wiring, VSS, ECM P0501 Vehicle speed sensor (VSS) ?? range/performance problem Wiring, speedometer, VSS, CAN data bus P0502 Vehicle speed sensor (VSS) ?? low input Wiring short to ground, VSS, ECM P0503 Vehicle speed sensor (VSS) ?? intermittent/erratic/high input Wiring, poor connection, other connected system, insturment panel, VSS P0504 Brake switch ?? A/B correlation Wiring, mechanical fault P0505 Idle speed control (ISC) system ?? malfunction Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM P0506 Idle speed control (ISC) system ?? rpm lower than expected Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM P0507 Idle speed control (ISC) system ?? rpm higher than expected Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM P0508 Idle air control (IAC) system ?? circuit low Wiring short to ground, IAC valve, ECM P0509 Idle air control (IAC) system ?? circuit high Wiring short to positive, IAC valve, ECM P0510 Closed throttle position (CTP) switch ?? circuit malfunction Wiring, CTP switch, ECM P0511 Idle air control (IAC) system ?? circuit malfunction Wiring, poor connection, IAC valve, ECM P0512 Starter request circuit ?? malfunction Wiring, immobilizer system, relay P0513 Incorrect immobilizer key Immobilizer system P0514 Battery temperature sensor ?? circuit range/performance Wiring, poor connection, battery temperature sensor P0515 Battery temperature sensor ?? circuit malfunction Wiring, poor connection, battery temperature sensor P0516 Battery temperature sensor ?? circuit low Wiring, short to ground, battery temperature sensor, ECM P0517 Battery temperature sensor ?? circuit high Wiring, short to positive, battery temperature sensor, ECM P0518 Idle air control (IAC) system ?? circuit intermittent Wiring, poor connection, IAC valve, ECM P0519 Idle air control (IAC) system ?? circuit performance Wiring, poor connection, IAC valve, ECM P0520 Engine oil pressure sensor/switch ?? circuit malfunction Wiring, engine oil pressure sensor/switch, ECM P0521 Engine oil pressure sensor/switch ?? range/performance problem Engine oil pressure sensor/switch P0522 Engine oil pressure sensor/switch ?? low voltage Wiring short to ground, engine oil pressure sensor/switch, ECM P0523 Engine oil pressure sensor/switch ?? high voltage Wiring short to positive, engine oil pressure sensor/switch, ECM P0524 Engine oil pressure too low Mechanical fault P0525 Cruise control, servo control ?? circuit range/performance Wiring, poor connection, cruise control servo P0526 Fan speed sensor ?? circuit malfunction Wiring, poor connection, fan speed sensor, ECM P0527 Fan speed sensor ?? circuit range/performance Wiring, poor connection, fan speed sensor P0528 Fan speed sensor ?? no signal Wiring, poor connection, fan speed sensor, ECM P0529 Fan speed sensor ?? circuit intermittent Wiring, poor connection, ECM P0530 AC refrigerant pressure sensor ?? circuit malfunction Wiring, AC refrigerant pressure sensor, ECM P0531 AC refrigerant pressure sensor ?? range/performance problem AC refrigerant pressure sensor P0532 AC refrigerant pressure sensor ?? low input AC refrigerant pressure too low (incorrectly charged), wiring, AC refrigerant pressure sensor, ECM P0533 AC refrigerant pressure sensor ?? high input AC refrigerant pressure too high (cooling fault/incorrectly charged), wiring, AC refrigerant pressure sensor, ECM P0534 AC refrigerant charge loss AC leak, wiring, AC refrigerant pressure sensor P0535 AC evaporator temperature sensor ?? circuit malfunction Wiring, poor connection, A/C evaporator temperature sensor, ECM P0536 AC evaporator temperature sensor ?? range/performance problem Wiring, poor connection, A/C evaporator temperature sensor, ECM P0537 AC evaporator temperature sensor ?? circuit low Wiring, short to gound, A/C evaporator temperature sensor, ECM P0538 AC evaporator temperature sensor ?? circuit high Wiring, short to positive, A/C evaporator temperature sensor, ECM P0539 AC evaporator temperature sensor ?? circuit intermittent Wiring, poor connection, A/C evaporator temperature sensor, ECM P0540 Intake air heater A ?? circuit malmunction Wiring, relay, intake air heater P0541 Intake air heater A ?? circuit low Wiring short to ground, intake air heater P0542 Intake air heater A ?? circuit high Wiring short to positive, intake air heater P0543 Intake air heater A ?? circuit open Wiring, intake air heater P0544 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 ?? circuit malfunction Wiring, EGRT sensor, ECM P0545 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 ?? low input Wiring short to ground, EGRT sensor, ECM P0546 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 ?? high input Wiring short to positive, EGRT sensor, ECM P0547 Exhaust gas temperature sensor, bank 2 sensor 1 ?? circuit malfunction Wiring, poor connection, exhaust gas temperature sensor, ECM P0548 Exhaust gas temperature sensor, bank 2 sensor 1 ?? circuit low Wiring short to ground, exhaust gas temperature sensor, ECM P0549 Exhaust gas temperature sensor, bank 2 sensor 1 ?? circuit high Wiring short to positive, exhaust gas temperature sensor, ECM P0550 Power steering pressure (PSP) sensor/switch ?? circuit malfunction Wiring, PSP sensor/switch, ECM P0551 Power steering pressure (PSP) sensor/switch ?? range/performance problem PAS system, PSP sensor/switch P0552 Power steering pressure (PSP) sensor/switch ?? low input Wiring short to ground, PSP sensor/switch, ECM P0553 Power steering pressure (PSP) sensor/switch ?? high input Wiring short to positive, PSP sensor/switch, ECM P0554 Power steering pressure (PSP) sensor/switch ?? circuit intermittent Wiring, poor connection, PSP sensor/switch, ECM P0555 Brake booster pressure sensor ?? circuit malfunction Wiring, poor connection, brake booster pressure sensor, ECM P0556 Brake booster pressure sensor ?? circuit range/performance Wiring, poor connection, brake booster pressure sensor, ECM P0557 Brake booster pressure sensor ?? circuit low input Wiring short to ground, brake booster pressure sensor, ECM P0558 Brake booster pressure sensor ?? circuit high input Wiring short to positive, brake booster pressure sensor, ECM P0559 Brake booster pressure sensor ?? circuit intermittent Wiring, poor connection, brake booster pressure sensor, ECM P0560 System voltage ?? malfunction Wiring, poor connection, battery, alternator P0561 System voltage ?? unstable Wiring, poor connection, battery, alternator P0562 System voltage ?? low Wiring, poor connection, battery, alternator P0563 System voltage ?? high Alternator P0564 Cruise control system, multi-function input A ?? circuit malfunction Wiring poor connection, multi-function switch, mechanical fault P0565 Cruise control master switch, ON signal ?? malfunction Wiring, cruise control master switch, ECM P0566 Cruise control master switch, OFF signal ?? malfunction Wiring, cruise control master switch, ECM P0567 Cruise control master switch, RESUME signal ?? malfunction Wiring, cruise control master switch, ECM P0568 Cruise control master switch, SET signal ?? malfunction Wiring, cruise control master switch, ECM P0569 Cruise control master switch, COAST signal ?? malfunction Wiring, cruise control master switch, ECM P0570 Cruise control system, APP sensor signal ?? malfunction Wiring, APP sensor, ECM P0571 Cruise/brake switch A ?? circuit malfunction Wiring, cruise/brake switch, ECM P0572 Cruise/brake switch A ?? circuit low Wiring short to ground, cruise/brake switch, ECM P0573 Cruise/brake switch A ?? circuit high Wiring short to positive, cruise/brake switch, ECM P0574 Cruise control system ??vehicle speed too high Mechanical fault P0575 Cruise control system ?? input circuit malfunction Wiring, poor connection, mechanical fault, ECM P0576 Cruise control system ?? input circuit low Wiring short to ground P0577 Cruise control system ?? input circuit high Wiring short to positive P0578 Cruise control system, multi-function input A ?? circuit stuck Wiring, poor connection, multi-function switch, mechanical fault P0579 Cruise control system, multi-function input A ?? circuit range/performance Wiring, poor connection, multi-function switch, mechanical fault P0580 Cruise control system, multi-function input A ?? circuit low Wiring short to ground, multi-function switch, mechanical fault P0581 Cruise control system, multi-function input A ?? circuit high Wiring short to positive, multi-function switch, mechanical fault P0582 Cruise control system, vacuum control ?? circuit open Wiring, vacuum control solenoid P0583 Cruise control system, vacuum control ?? circuit low Wiring short to ground, vacuum control solenoid P0584 Cruise control system, vacuum control ?? circuit high Wiring short to positive, vacuum control solenoid P0585 Cruise control system, multi-function input A/B ?? correlation Mechanical fault P0586 Cruise control system, vent control ?? circuit open Wiring, vent control solenoid P0587 Cruise control system, vent control ?? circuit low Wiring short to ground, vent control solenoid P0588 Cruise control system, vent control ?? circuit high Wiring short to positive, vent control solenoid P0589 Cruise control system, multi-function input B ?? circuit malfunction Wiring, poor connection, multi-function switch, mechanical fault P0590 Cruise control system, multi-function input B ?? circuit stuck Wiring, poor connection, multi-function switch, mechanical fault P0591 Cruise control system, multi-function input B ?? circuit range/performance Wiring, poor connection, multi-function switch, mechanical fault P0592 Cruise control system, multi-function input B ?? circuit low Wiring short to ground, multi-function switch, mechanical fault P0593 Cruise control system, multi-function input B ?? circuit high Wiring short to positive, multi-function switch, mechanical fault P0594 Cruise control system, servo control ?? circuit open Wiring, servo control solenoid P0595 Cruise control system, servo control ?? circuit low Wiring short to ground, servo control solenoid P0596 Cruise control system, servo control ?? circuit high Wiring short to positive, servo control solenoid P0597 Thermostat heater control system ?? circuit open Wiring, relay, thermostat heater P0598 Thermostat heater control system ?? circuit low Wiring short to ground, relay, thermostat heater P0599 Thermostat heater control system ?? circuit high Wiring short to positive, relay, thermostat heater P0600 CAN date bus ?? malfunction Wiring, connected system, ECM P0601 Engine control module (ECM) ?? memory check sum error ECM P0602 Engine control module (ECM) ?? programming error ECM P0603 Engine control module (ECM) ?? KAM error ECM P0604 Engine control module (ECM) ?? RAM error ECM P0605 Engine control module (ECM) ?? ROM error ECM P0606 Engine control module (ECM) ?? processor fault ECM P0607 Control module ?? performance Control module P0608 Engine control module (ECM), VSS output A ?? malfunction ECM P0609 Engine control module (ECM), VSS output B ?? malfunction ECM P0610 Control module ?? vehicle options error Control module P0611 Fuel injector control module ?? performance Fuel injector control module P0612 Fuel injector control module ?? relay control circuit Wiring, relay,fuel injector control module P0613 Transmission control module (TCM) processor error TCM P0614 Engine control module (ECM)/Transmission control module (TCM) ?? mismatch ECM/TCM P0615 Starter relay ?? circuit malfunction Wiring, poor connection, starter relay, ECM P0616 Starter relay ?? circuit low Wiring short to ground, starter relay, ECM P0617 Starter relay ?? circuit high Wiring short to positive, starter relay, ECM P0618 Alternative fuel control module ?? KAM error alternative fuel control module P0619 Alternative fuel control module ?? RAM/ROM error alternative fuel control module P0620 Alternator, control ?? circuit malfunction Wiring, alternator, battery, ECM P0621 Alternator warning lamp?? circuit malfunction Wiring, alternator warning lamp, ECM P0622 Alternator, field control ?? circuit malfunction Wiring, alternator, battery, ECM P0623 Generator lamp control ?? circuit malfunction Wiring, poor connection, bulb, ECM P0624 Fuel cap lamp control ?? circuit malfunction Wiring, poor connection, bulb, ECM P0625 Generator field terminal ?? circuit low Wiring short to ground, generator P0626 Generator field terminal ?? circuit high Wiring short to positive, generator P0627 Fuel pump control ?? circuit open Wiring, relay, fuel pump P0628 Fuel pump control ?? circuit low Wiring short to ground, relay, fuel pump P0629 Fuel pump control ?? circuit high Wiring short to positive, relay, fuel pump P0630 VIN not programmed or mismatch ?? ECM ECM P0631 VIN not programmed or mismatch ?? TCM TCM P0632 Odometer not programmed ?? ECM ECM P0633 Immobilizer key not programmed ?? ECM ECM P0634 ECM/TCM ?? internal termperature too high Mechanical fault, ECM/TCM P0635 Power steering (PAS) control ?? circuit malfunction Wiring, poor connection, PAS pressure switch, ECM P0636 Power steering (PAS) control ?? circuit low Wiring short to ground, PAS pressure switch, ECM P0637 Power steering (PAS) control ?? circuit high Wiring short to positive, PAS pressure switch, ECM P0638 Throttle actuator control, bank 1 ?? range/performance problem Basic setting not carried out (if applicable), ISC actuator/throttle motor, APP sensor P0639 Throttle actuator control, bank 2 ?? range/performance Wiring, throttle control unit P0640 Intake air heater control ?? circuit malfunction Wiring, relay, intake air heater P0641 Sensor reference voltage A ?? circuit open Wiring short to positive P0642 Engine control module (ECM), knock control ?? defective ECM P0643 Sensor reference voltage A ?? circuit high Wiring short to positive P0644 Driver display, serial communication ?? circuit malfunction Wiring, CAN data bus, ECM P0645 Air conditioning (AC) Wiring, AC system P0646 A/C clutch relay control ?? circuit low Wiring short to ground, A/C clutch relay P0647 A/C clutch relay control ?? circuit high Wiring short to positive, A/C clutch relay P0648 Immobilizer lamp control ?? circuit malfunction Wiring, poor connection, bulb, ECM P0649 Cruise control lamp control ?? circuit Wiring, poor connection, bulb, ECM P0650 Malfunction indicator lamp (MIL) ?? circuit malfunction Wiring, MIL, ECM P0651 Sensor reference voltage B ?? circuit open Wiring short to positive P0652 Sensor reference voltage B ?? circuit low Wiring short to ground P0653 Sensor reference voltage B ?? circuit high Wiring short to positive P0654 Engine rpm, output ?? circuit malfunction Wiring, ECM P0655 Engine hot lamp output ?? circuit malfunction Wiring, engine hot lamp, ECM P0656 Fuel level output ?? circuit malfunction Wiring, ECM P0657 Actuator supply voltage ?? circuit open Wiring P0658 Actuator supply voltage ?? circuit low Wiring short to ground, actuator P0659 Actuator supply voltage ?? circuit high Wiring short to positive, actuator P0660 Intake manifold tuning valve, bank 1 ?? circuit open Wiring, intake manifold tuning valve P0661 Intake manifold tuning valve, bank 1 ?? circuit low Wiring short to ground, intake manifold tuning valve P0662 Intake manifold tuning valve, bank 1 ?? circuit high Wiring short to positive, intake manifold tuning valve P0663 Intake manifold tuning valve, bank 2 ?? circuit open Wiring, intake manifold tuning valve P0664 Intake manifold tuning valve, bank 2 ?? circuit low Wiring short to ground, intake manifold tuning valve P0665 Intake manifold tuning valve, bank 2 ?? circuit high Wiring short to positive, intake manifold P0666 ECM/TCM internal termperature sensor ?? circuit malfunction Wiring, poor connection, internal temperature sensor, ECM/TCM P0667 ECM/TCM internal termperature sensor ?? range/performance Wiring, poor connection, internal temperature sensor, ECM/TCM P0668 ECM/TCM internal termperature sensor ?? circuit low Wiring short to ground, internal temperature sensor, ECM/TCM P0669 ECM/TCM internal termperature sensor ?? circuit high Wiring short to positive, internal temperature sensor, ECM/TCM P0670 Glow plug module control ?? circuit malfunction Wiring, poor connection, control module, glow plug, ECM P0671 Glow plug, cylinder 1 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0672 Glow plug, cylinder 2 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0673 Glow plug, cylinder 3 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0674 Glow plug, cylinder 4 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0675 Glow plug, cylinder 5 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0676 Glow plug, cylinder 6 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0677 Glow plug, cylinder 7 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0678 Glow plug, cylinder 8 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0679 Glow plug, cylinder 9 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0680 Glow plug, cylinder 10 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0681 Glow plug, cylinder 11 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0682 Glow plug, cylinder 12 ?? circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0683 Glow plug control module communication to ECM ?? malfunction Wiring, poor connection, control module, ECM P0684 Glow plug control module communication to ECM ?? range/performance Wiring, poor connection, control module, ECM P0685 ECM power relay control ?? circuit open Wiring, ECM relay P0686 ECM power relay control ?? circuit low Wiring short to ground, ECM relay, ECM P0687 Engine control relay ?? short to ground Wiring short to ground, engine control relay, ECM P0688 Engine control relay ?? short to positive Wiring short to positive, engine control relay, ECM P0689 ECM power relay sense ?? circuit low Wiring short to ground, ECM relay, ECM P0690 ECM power relay sense ?? circuit high Wiring short to positive, ECM relay, ECM P0691 Engine coolant blower motor 1 ?? short to ground Wiring short to ground, engine coolant blower motor, ECM P0692 Engine coolant blower motor 1 ?? short to positive Wiring short to positive, engine coolant blower motor, ECM P0693 Engine coolant blower motor 2 ?? short to ground Wiring short to ground, engine coolant blower motor, ECM P0694 Engine coolant blower motor 2 ?? short to positive Wiring short to positive, engine coolant blower motor, ECM P0695 Fan 3 control ?? circuit low Wiring short to ground, fan motor P0696 Fan 3 control ?? circuit high Wiring short to positive, fan motor P0697 Sensor reference voltage C ?? circuit open Wiring short to positive P0698 Sensor reference voltage C ?? circuit low Wiring short to ground P0699 Sensor reference voltage C ?? circuit high Wiring short to positive P0700 Transmission control system ?? malfunction Wiring, TCM P0701 Transmission control system ?? range/performance problem Wiring, TCM P0702 Transmission control system ?? electrical Wiring, TCM P0703 Torque converter/brake switch B ?? circuit malfunction Wiring, torque converter/brake switch, ECM//TCM P0704 Clutch pedal position (CPP) switch ?? circuit malfunction Wiring, CPP switch, ECM/TCM P0705 Transmission range (TR) sensor/switch, PRNDL input ?? circuit malfunction Wiring, TR sensor/switch, ECM/TCM P0706 Transmission range (TR) sensor/switch ?? range/performance problem Wiring, TR sensor/switch P0707 Transmission range (TR) sensor/switch ?? low input Wiring short to ground, TR sensor/switch, ECM/TCM P0708 Transmission range (TR) sensor/switch ??high input Wiring short to positive, TR sensor/switch, ECM/TCM P0709 Transmission range (TR) sensor/switch ?? circuit intermittent Wiring, poor connection, TR sensor/switch, ECM/TCM P0710 Transmission fluid temperature (TFT) sensor ?? circuit malfunction Wiring, TFT sensor, ECM, ECM/TCM P0711 Transmission fluid temperature (TFT) sensor ?? range/performance problem Wiring, TFT sensor P0712 Transmission fluid temperature (TFT) sensor ?? low input Wiring short to ground, TFT sensor, ECM, ECM/TCM P0713 Transmission fluid temperature (TFT) sensor ?? high input Wiring short to ground, TFT sensor, ECM, ECM/TCM P0714 Transmission fluid temperature (TFT) sensor ?? circuit intermittent Wiring, poor connection, TFT sensor, ECM, ECM/TCM P0715 Turbine shaft speed (TSS) sensor ?? circuit malfunction Wiring, TSS sensor, ECM/TCM P0716 Turbine shaft speed (TSS) sensor ?? range/performance problem Wiring, TSS sensor P0717 Turbine shaft speed (TSS) sensor ?? no signal Wiring, TSS sensor, ECM/TCM P0718 Turbine shaft speed (TSS) sensor ?? circuit intermittent Wiring, poor connection, TSS sensor, ECM/TCM P0719 Torque converter/brake switch B ?? circuit low Wiring short to ground, torque converter/brake switch, ECM/TCM P0720 Output shaft speed (OSS) sensor ?? circuit malfunction Wiring, OSS sensor, ECM/TCM P0721 Output shaft speed (OSS) sensor ?? range/performance problem Wiring, OSS sensor P0722 Output shaft speed (OSS) sensor ?? no signal Wiring, OSS sensor, ECM/TCM P0723 Output shaft speed (OSS) sensor ?? circuit intermittent Wiring, poor connection, OSS sensor, ECM/TCM P0724 Torque converter/brake switch B ?? circuit high Wiring short to positive, torque converter/brake switch, ECM/TCM P0725 Engine RPM input ?? circuit malfunction Wiring, CKP/RPM sensor, ECM/TCM P0726 Engine RPM input ?? range/performance problem Wiring, CKP/RPM sensor P0727 Engine RPM input ?? no signal Wiring, CKP/RPM sensor, ECM/TCM P0728 Engine RPM input ?? circuit intermittent Wiring, poor connection, CKP/RPM sensor, ECM/TCM P0730 Incorrect gear ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0731 Gear 1 ?? incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0732 Gear 2 ?? incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0733 Gear 3 ?? incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0734 Gear 4 ?? incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0735 Gear 5 ?? incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0736 Reverse ?? incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0737 TCM engine speed output ?? circuit Wiring, TCM P0738 TCM engine speed output ?? circuit low Wiring, TCM P0739 TCM engine speed output ?? circuit high Wiring, TCM P0740 Torque converter clutch (TCC) solenoid ?? circuit malfunction Wiring, TCC solenoid, ECM/TCM P0741 Torque converter clutch (TCC) solenoid ?? performance or stuck off Wiring, TCC solenoid P0742 Torque converter clutch (TCC) solenoid ?? stuck on Wiring, TCC solenoid P0743 Torque converter clutch (TCC) solenoid ?? electrical Wiring, TCC solenoid, ECM/TCM P0744 Torque converter clutch (TCC) solenoid ?? circuit intermittent Wiring, poor connection, TCC solenoid, ECM/TCM P0745 Transmission fluid pressure (TFP) solenoid ?? circuit malfunction Wiring, TFP solenoid, ECM/TCM P0746 Transmission fluid pressure (TFP) solenoid ?? performance or stuck off Wiring, TFP solenoid P0747 Transmission fluid pressure (TFP) solenoid ?? stuck on Wiring, TFP solenoid P0748 Transmission fluid pressure (TFP) solenoid ?? electrical Wiring, TFP solenoid, ECM/TCM P0749 Transmission fluid pressure (TFP) solenoid ?? circuit intermittent Wiring, poor connection, TFP solenoid, ECM/TCM P0750 Shift solenoid (SS) A ?? circuit malfunction Wiring, shift solenoid, ECM/TCM P0751 Shift solenoid (SS) A ?? performance or stuck off Wiring, shift solenoid P0752 Shift solenoid (SS) A ?? stuck on Wiring, shift solenoid P0753 Shift solenoid (SS) A ?? electrical Wiring, shift solenoid, ECM/TCM P0754 Shift solenoid (SS) A ?? circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0755 Shift solenoid (SS) B ?? circuit malfunction Wiring, shift solenoid, ECM/TCM P0756 Shift solenoid (SS) B ?? performance or stuck off Wiring, shift solenoid P0757 Shift solenoid (SS) B ?? stuck on Wiring, shift solenoid P0758 Shift solenoid (SS) B ?? electrical Wiring, shift solenoid, ECM/TCM P0759 Shift solenoid (SS) B ?? circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0760 Shift solenoid (SS) C ?? circuit malfunction Wiring, shift solenoid, ECM/TCM P0761 Shift solenoid (SS) C ?? performance or stuck off Wiring, shift solenoid P0762 Shift solenoid (SS) C ?? stuck on Wiring, shift solenoid P0763 Shift solenoid (SS) C ?? electrical Wiring, shift solenoid, ECM/TCM P0764 Shift solenoid (SS) C ?? circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0765 Shift solenoid (SS) D ?? circuit malfunction Wiring, shift solenoid, ECM/TCM P0766 Shift solenoid (SS) D ?? performance or stuck off Wiring, shift solenoid P0767 Shift solenoid (SS) D ?? stuck on Wiring, shift solenoid P0768 Shift solenoid (SS) D ?? electrical Wiring, shift solenoid, ECM/TCM P0769 Shift solenoid (SS) D ?? circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0770 Shift solenoid (SS) E ?? circuit malfunction Wiring, shift solenoid, ECM/TCM P0771 Shift solenoid (SS) E ?? performance or stuck off Wiring, shift solenoid P0772 Shift solenoid (SS) E ?? stuck on Wiring, shift solenoid P0773 Shift solenoid (SS) E ?? electrical Wiring, shift solenoid, ECM/TCM P0774 Shift solenoid (SS) E ?? circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0775 Pressure control solenoid B ?? malfunction Pressure control solenoid P0776 Pressure control solenoid B ?? performance or stuck off Wiring, pressure control solenoid P0777 Pressure control solenoid B ?? stuck on Wiring, pressure control solenoid P0778 Pressure control solenoid B ?? electrical Wiring, pressure control solenoid P0779 Pressure control solenoid B ?? intermittent Wiring, poor connection, pressure control solenoid P0780 Gear selection ?? shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0781 Gear selection, 1-2 ?? shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0782 Gear selection, 2-3 ?? shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0783 Gear selection, 3-4 ?? shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0784 Gear selection, 4-5 ?? shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0785 Shift/timing solenoid ?? circuit malfunction Wiring, shift/timing solenoid, ECM/TCM P0786 Shift/timing solenoid ?? range/performance problem Wiring, shift/timing solenoid P0787 Shift/timing solenoid ?? low Wiring short to ground, shift/timing solenoid, ECM/TCM P0788 Shift/timing solenoid ?? high Wiring short to positive, shift/timing solenoid, ECM/TCM P0789 Shift/timing solenoid ?? intermittent Wiring, poor connection, shift/timing solenoid, ECM/TCM P0790 Transmission mode selection switch ?? circuit malfunction Wiring, transmission mode selection switch, ECM/TCM P0791 Intermediate shaft speed sensor ?? circuit malfunction Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM P0792 Intermediate shaft speed sensor ?? range/performance problem Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM P0793 Intermediate shaft speed sensor ?? no signal Wiring, poor connection,short to ground, intermediate shaft speed sensor, ECM/TCM P0794 Intermediate shaft speed sensor ?? intermittent circuit malfunction Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM P0795 Transmisssion fluid pressure (TFP) solenoid C ?? circuit malfunction Wiring, poor connection, TFP solenoid, ECM/TCM P0796 Transmisssion fluid pressure (TFP) solenoid C ?? performance or stuck off Wiring, poor connection, TFP solenoid, ECM/TCM P0797 Transmisssion fluid pressure (TFP) solenoid C ?? stuck on Wiring, poor connection, TFP solenoid, ECM/TCM P0798 Transmisssion fluid pressure (TFP) solenoid C ?? electrical malfunction Wiring, poor connection, TFP solenoid, ECM/TCM P0799 Transmisssion fluid pressure (TFP) solenoid C ?? intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0800 Transfer case control system, MIL request ?? malfunction Wiring, mechanical fault P0801 Reverse inhibit circuit ?? malfunction Wiring, poor connection P0802 Transmission control system, MIL request ?? circuit open Wiring, mechanical fault P0803 1-4 Upshift (Skip shift) solenoid ?? circuit malfunction Wiring, poor connection, upshift solenoid P0804 1-4 Upshift (Skip shift) warning lamp ?? circuit malfunction Wiring, poor connection P0805 Clutch position sensor ?? circuit malfunction Wiring, poor connection, clutch position sensor, ECM/TCM P0806 Clutch position sensor ?? range/performance problem Wiring, poor connection, clutch position sensor, ECM/TCM P0807 Clutch position sensor ?? low input Wiring, short to ground, clutch position sensor, ECM/TCM P0808 Clutch position sensor ?? high input Wiring, short to positive, clutch position sensor, ECM/TCM P0809 Clutch position sensor ?? intermittent circuit malfunction Wiring, poor connection, clutch position sensor, ECM/TCM P0810 Clutch position control error Wiring, poor connection, ECM/TCM P0811 Excessive clutch slip Wiring, poor connection, mechanical fault, ECM/TCM P0812 Reverse gear ?? input circuit malfunction Wiring, poor connection, ECM/TCM P0813 Reverse gear ?? output circuit malfunction Wiring, poor connection, ECM/TCM P0814 Transmission range (TR) display ?? circuit malfunction Wiring, poor connection, TR sensor, ECM/TCM P0815 Upshift switch ?? circuit malfunction Wiring, poor connection, upshift switch, ECM/TCM P0816 Downshift switch ?? circuit malfunction Wiring, poor connection, downshift switch, ECM/TCM P0817 Starter disable circuit ?? malfunction Wiring, poor connection, ECM/TCM P0818 Driveline disconnect switch ?? circuit malfunction Wiring, poor connection, upshift switch, ECM/TCM P0819 Up and down shift switch to transmission range ?? correlation Wiring, poor connection,TR sensor, ECM/TCM P0820 Gear lever X-Y position sensor ?? circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM P0821 Gear lever X position sensor ?? circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM P0822 Gear lever Y position sensor ?? circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM P0823 Gear lever X position sensor ?? circuit intermittent Wiring, poor connection, gear lever position sensor, ECM/TCM P0824 Gear lever Y position sensor ?? circuit intermittent Wiring, poor connection, gear lever position sensor, ECM/TCM P0825 Gear lever push-pull switch ?? circuit malfunction Wiring, poor connection, gear lever push-pull switch, ECM/TCM P0826 Up and down switch ?? input circuit Wiring, Up/down switch P0827 Up and down switch ?? input circuit low Wiring short to ground, Up/down switch P0828 Up and down switch ?? input circuit high Wiring short to positive, Up/down switch P0829 5-6 Shift Mechanical fault P0830 Clutch pedal position (CPP) switch A ?? circuit malfunction Wiring, poor connection, CPP switch, ECM/TCM P0831 Clutch pedal position (CPP) switch A ?? low input Wiring, short to ground, CPP switch, ECM/TCM P0832 Clutch pedal position (CPP) switch A ?? high input Wiring, short to positive, CPP switch, ECM/TCM P0833 Clutch pedal position (CPP) switch B ?? circuit malfunction Wiring, poor connection, CPP switch, ECM/TCM P0834 Clutch pedal position (CPP) switch B ?? low input Wiring, short to ground, CPP switch, ECM/TCM P0835 Clutch pedal position (CPP) switch B ?? high input Wiring, short to positive, CPP switch, ECM/TCM P0836 Four wheel drive switch ?? circuit malfunction Wiring, poor connection, four wheel drive switch, ECM/TCM P0837 Four wheel drive switch ?? range/performance problem Wiring, poor connection, four wheel drive switch, ECM/TCM P0838 Four wheel drive switch ?? low input Wiring, short to ground, four wheel drive switch, ECM/TCM P0839 Four wheel drive switch ?? high input Wiring, short to positive, four wheel drive switch, ECM/TCM P0840 Transmission fluid pressure (TFP) sensor A ?? circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A ?? circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0841 Transmission fluid pressure (TFP) sensor A ?? range/performance problem Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A ?? range/performance problem Wiring, poor connection, TFP switch, ECM/TCM P0842 Transmission fluid pressure (TFP) sensor A ?? low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A ?? low input Wiring, short to ground, TFP switch, ECM/TCM P0843 Transmission fluid pressure (TFP) sensor A ?? high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A ?? high input Wiring, short to positive, TFP switch, ECM/TCM P0844 Transmission fluid pressure (TFP) sensor A ?? intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A ?? intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0845 Transmission fluid pressure (TFP) sensor B ?? circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B ?? circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0846 Transmission fluid pressure (TFP) sensor B ?? range/performance problem Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B ?? range/performance problem Wiring, poor connection, TFP switch, ECM/TCM P0847 Transmission fluid pressure (TFP) sensor B ?? low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B ?? low input Wiring, short to ground, TFP switch, ECM/TCM P0848 Transmission fluid pressure (TFP) sensor B ?? high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B ?? high input Wiring, short to positive, TFP switch, ECM/TCM P0849 Transmission fluid pressure (TFP) sensor B ?? intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B ?? intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0850 Park/neutral position (PNP) switch ?? input circuit malfunction Wiring, PNP switch, ECM/TCM P0851 Park/neutral position (PNP) switch ?? input circuit low Wiring, short to ground, PNP switch, ECM/TCM P0852 Park/neutral position (PNP) switch ?? input circuit high Wiring, short to positive, PNP switch, ECM/TCM P0853 Drive switch ?? input circuit malfunction Wiring, drive switch, ECM/TCM P0854 Drive switch ?? input circuit low Wiring, short to ground, drive switch, ECM/TCM P0855 Drive switch ?? input circuit high Wiring, short to positive, drive switch, ECM/TCM P0856 Traction control input signal ?? malfunction Wiring, poor connection, ECM/TCM P0857 Traction control input signal ?? range/performance problem Wiring, poor connection, ECM/TCM P0858 Traction control input signal ?? low Wiring, short to ground, ECM/TCM P0859 Traction control input signal ?? high Wiring, short to positive, ECM/TCM P0860 Gear shift module communication circuit ?? malfunction Wiring, poor connection, gear shift module, ECM/TCM P0861 Gear shift module communication circuit ?? low input Wiring, short to ground, gear shift module, ECM/TCM P0862 Gear shift module communication circuit ?? low input Wiring, short to positive, gear shift module, ECM/TCM P0863 Transmission control module (TCM) communication circuit ?? malfunction Wiring, poor connection, TCM P0864 Transmission control module (TCM) communication circuit ?? range/performance problem Wiring, poor connection, TCM P0865 Transmission control module (TCM) communication circuit ?? low input Wiring, short to ground, TCM P0866 Transmission control module (TCM) communication circuit ?? high input Wiring, short to positive, TCM P0867 Transmission fluid pressure (TFP) sensor Wiring, poor connection, TFP switch, ECM/TCM P0868 Transmission fluid pressure (TFP) sensor ?? low Wiring, short to ground, TFP switch, ECM/TCM P0869 Transmission fluid pressure (TFP) sensor ?? high Wiring, short to positive, TFP switch, ECM/TCM P0870 Transmission fluid pressure (TFP) sensor C ?? circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C ?? circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0871 Transmission fluid pressure (TFP) sensor C ?? range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C ?? range/performance Wiring, poor connection, TFP switch, ECM/TCM P0872 Transmission fluid pressure (TFP) sensor C ?? low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C ?? low input Wiring, short to ground, TFP switch, ECM/TCM P0873 Transmission fluid pressure (TFP) sensor C ?? high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C ?? high input Wiring, short to positive, TFP switch, ECM/TCM P0874 Transmission fluid pressure (TFP) sensor C ?? intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C ?? intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0875 Transmission fluid pressure (TFP) sensor D ?? circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D ?? circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0876 Transmission fluid pressure (TFP) sensor D ?? range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D ?? range/performance Wiring, poor connection, TFP switch, ECM/TCM P0877 Transmission fluid pressure (TFP) sensor D ?? low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D ?? low input Wiring, short to ground, TFP switch, ECM/TCM P0878 Transmission fluid pressure (TFP) sensor D ?? high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D ?? high input Wiring, short to positive, TFP switch, ECM/TCM P0879 Transmission fluid pressure (TFP) sensor D ?? intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D ?? intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0880 Transmission control module (TCM) ?? power input signal malfunction Wiring, poor connection, TCM P0881 Transmission control module (TCM) ?? power input signal range/performance Wiring, poor connection, TCM P0882 Transmission control module (TCM) ?? power input signal low Wiring, short to ground, TCM P0883 Transmission control module (TCM) ?? power input signal high Wiring, short to positive, TCM P0884 Transmission control module (TCM) ?? power input signal intermittent malfunction Wiring, poor connection, TCM P0885 Transmission control module (TCM) power relay ?? control circuit open Wiring, poor connection, TCM power relay, TCM P0886 Transmission control module (TCM) power relay ?? control circuit low Wiring, short to ground, TCM power relay, TCM P0887 Transmission control module (TCM) power relay ?? control circuit high Wiring, short to positive, TCM power relay, TCM P0888 Transmission control module (TCM) power relay ?? sense circuit malfunction Wiring, poor connection, TCM power relay, TCM P0889 Transmission control module (TCM) power relay ?? sense circuit range/performance Wiring, poor connection, TCM power relay, TCM P0890 Transmission control module (TCM) power relay ?? sense circuit low Wiring, short to ground, TCM power relay, TCM P0891 Transmission control module (TCM) power relay ?? sense circuit high Wiring, short to positive, TCM power relay, TCM P0892 Transmission control module (TCM) power relay ?? sense circuit intermittent malfunction Wiring, poor connection, TCM power relay, TCM P0893 Multiple gears engaged Mechanical fault P0894 Transmission component slipping Mechanical fault P0895 Shift time too short Mechanical fault P0896 Shift time too long Mechanical fault P0897 Transmission fluid deteriorated Mechanical fault P0898 Transmission control system ?? MIL request ?? circuit low Wiring, poor connection, short to ground P0899 Transmission control system ?? MIL request ?? circuit high Wiring, poor connection, short to positive P0900 Clutch actuator ?? circuit open Wiring, clutch actuator, ECM/TCM P0901 Clutch actuator ?? circuit range/performance Wiring, poor connection, clutch actuator, ECM/TCM P0902 Clutch actuator ?? circuit low Wiring, short to ground, clutch actuator, ECM/TCM P0903 Clutch actuator ?? circuit high Wiring, short to positive, clutch actuator, ECM/TCM P0904 Transmission gate select position circuit ?? malfunction Wiring, poor connection, ECM/TCM P0905 Transmission gate select position circuit ?? range/performance Wiring, poor connection, ECM/TCM P0906 Transmission gate select position circuit ?? low Wiring, short to ground, ECM/TCM P0907 Transmission gate select position circuit ?? high Wiring, short to positive, ECM/TCM P0908 Transmission gate select position circuit ?? intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0909 Transmission gate select control error Mechanical fault P0910 Transmission gate select actuator ?? circuit open Wiring, transmission gate select actuator, ECM/TCM P0911 Transmission gate select actuator ?? circuit range/performance Wiring, poor connection, transmission gate select actuator, ECM/TCM P0912 Transmission gate select actuator ?? circuit low Wiring, short to ground, transmission gate select actuator, ECM/TCM P0913 Transmission gate select actuator ?? circuit high Wiring, short to positive, transmission gate select actuator, ECM/TCM P0914 Gear shift position circuit ?? malfunction Wiring, poor connection, ECM/TCM P0915 Gear shift position circuit ?? range/performance Wiring, poor connection, ECM/TCM P0916 Gear shift position circuit ?? low Wiring, short to ground, ECM/TCM P0917 Gear shift position circuit ?? high Wiring, short to positive, ECM/TCM P0918 Gear shift position circuit ?? intermittent malfunction Wiring, poor connection, ECM/TCM P0919 Gear shift position control ?? error Wiring, poor connection, ECM/TCM P0820 Gear shift forward actuator ?? circuit open Wiring, gear shift forward actuator, ECM/TCM P0821 Gear shift forward actuator ?? circuit range/performance Wiring, poor connection, gear shift forward actuator, ECM/TCM P0822 Gear shift forward actuator ?? circuit low Wiring, short to ground, gear shift forward actuator, ECM/TCM P0823 Gear shift forward actuator ?? circuit high Wiring, short to positive, gear shift forward actuator, ECM/TCM P0824 Gear shift reverse actuator ?? circuit open Wiring, gear shift reverse actuator, ECM/TCM P0825 Gear shift reverse actuator ?? circuit range/performance Wiring, poor connection, gear shift reverse actuator, ECM/TCM P0826 Gear shift reverse actuator ?? circuit low Wiring, short to ground, gear shift reverse actuator, ECM/TCM P0927 Gear shift reverse actuator ?? circuit high Wiring, short to positive, gear shift reverse actuator, ECM/TCM P0928 Gear shift lock solenoid ?? circuit open Wiring, gear shift lock solenoid, ECM/TCM P0929 Gear shift lock solenoid ?? circuit range/performance Wiring, gear shift lock solenoid, ECM/TCM P0930 Gear shift lock solenoid ?? circuit low Wiring, short to ground, gear shift lock solenoid, ECM/TCM P0931 Gear shift lock solenoid ?? circuit high Wiring, short to positive, gear shift lock solenoid, ECM/TCM P0932 Hydraulic pressure sensor ?? circuit malfunction Wiring, poor connection, hydraulic pressure sensor, ECM/TCM P0933 Hydraulic pressure sensor ?? range/performance Wiring, hydraulic pressure sensor, ECM/TCM P0934 Hydraulic pressure sensor ?? circuit low input Wiring, short to ground, hydraulic pressure sensor, ECM/TCM P0935 Hydraulic pressure sensor ?? circuit high input Wiring, short to positive, hydraulic pressure sensor, ECM/TCM P0936 Hydraulic pressure sensor ?? circuit intermittent Wiring, poor connection, hydraulic pressure sensor, ECM/TCM P0937 Hydraulic oil temperature sensor ?? circuit malfunction Wiring, poor connection, hydraulic oil temperature sensor, ECM/TCM P0938 Hydraulic oil temperature sensor ?? range/performance Wiring, hydraulic oil temperature sensor, ECM/TCM P0939 Hydraulic oil temperature sensor ?? circuit low input Wiring, short to ground, hydraulic oil temperature sensor, ECM/TCM P0940 Hydraulic oil temperature sensor ?? circuit high input Wiring, short to positive, hydraulic oil temperature sensor, ECM/TCM P0941 Hydraulic oil temperature sensor ?? circuit intermittent Wiring, poor connection, hydraulic oil temperature sensor, ECM/TCM P0942 Hydraulic pressure unit Mechanical fault P0943 Hydraulic pressure unit ?? cycling period too short Mechanical fault P0944 Hydraulic pressure unit ?? loss of pressure Mechanical fault P0945 Hydraulic pump relay ?? circuit open Wiring, hydraulic pump relay, ECM/TCM P0946 Hydraulic pump relay ?? circuit range/performance Wiring, hydraulic pump relay, ECM/TCM P0947 Hydraulic pump relay ?? circuit low Wiring, short to ground, hydraulic pump relay, ECM/TCM P0948 Hydraulic pump relay ?? circuit high Wiring, short to positive, hydraulic pump relay, ECM/TCM P0949 ASM ?? adaptive learning not done ECM/TCM P0850 ASM control circuit Wiring, poor connection, ECM/TCM P0851 ASM control circuit ?? range/performance Wiring, poor connection, ECM/TCM P0852 ASM control circuit ?? low Wiring, poor connection, short to ground, ECM/TCM P0853 ASM control circuit ?? high Wiring, poor connection, short to positive, ECM/TCM P0854 ASM ?? intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0855 ASM mode circuit ?? malfunction Wiring, poor connection, ECM/TCM P0856 ASM mode circuit ?? range/performance Wiring, poor connection, ECM/TCM P0957 ASM mode circuit ?? low Wiring, poor connection, short to ground, ECM/TCM P0958 ASM mode circuit ?? high Wiring, poor connection, short to positive, ECM/TCM P0959 ASM mode circuit ?? intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0960 Pressure control (PC) solenoid A ?? control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM P0961 Pressure control (PC) solenoid A ?? control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM P0962 Pressure control (PC) solenoid A ?? control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM P0963 Pressure control (PC) solenoid A ?? control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM P0964 Pressure control (PC) solenoid B ?? control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM P0965 Pressure control (PC) solenoid B ?? control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM P0966 Pressure control (PC) solenoid B ?? control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM P0967 Pressure control (PC) solenoid B ?? control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM P0968 Pressure control (PC) solenoid C ?? control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM P0969 Pressure control (PC) solenoid C ?? control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM P0970 Pressure control (PC) solenoid C ?? control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM P0971 Pressure control (PC) solenoid C ?? control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM P0972 Shift solenoid (SS) A ?? control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0973 Shift solenoid (SS) A ?? control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0974 Shift solenoid (SS) A ?? control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0975 Shift solenoid (SS) B ?? control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0976 Shift solenoid (SS) B ?? control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0977 Shift solenoid (SS) B ?? control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0978 Shift solenoid (SS) C ?? control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0979 Shift solenoid (SS) C ?? control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0980 Shift solenoid (SS) C ?? control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0981 Shift solenoid (SS) D ?? control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0982 Shift solenoid (SS) D ?? control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0983 Shift solenoid (SS) D ?? control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0984 Shift solenoid (SS) E ?? control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0985 Shift solenoid (SS) E ?? control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0986 Shift solenoid (SS) E ?? control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0987 Transmission fluid pressure (TFP) sensor E ?? circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E ?? circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0988 Transmission fluid pressure (TFP) sensor E ?? circuit range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E ?? circuit range/performance Wiring, poor connection, TFP switch, ECM/TCM P0989 Transmission fluid pressure (TFP) sensor E ?? circuit low Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E ?? circuit low Wiring, short to ground, TFP switch, ECM/TCM P0990 Transmission fluid pressure (TFP) sensor E ?? circuit high Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E ?? circuit high Wiring, short to positive, TFP switch, ECM/TCM P0991 Transmission fluid pressure (TFP) sensor E ?? circuit intermittent Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E ?? circuit intermittent Wiring, poor connection, TFP switch, ECM/TCM P0992 Transmission fluid pressure (TFP) sensor F ?? circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F ?? circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0993 Transmission fluid pressure (TFP) sensor F ?? circuit range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F ?? circuit range/performance Wiring, poor connection, TFP switch, ECM/TCM P0994 Transmission fluid pressure (TFP) sensor F ?? circuit low Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F ?? circuit low Wiring, short to ground, TFP switch, ECM/TCM P0995 Transmission fluid pressure (TFP) sensor F ?? circuit high Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F ?? circuit high Wiring, short to positive, TFP switch, ECM/TCM P0996 Transmission fluid pressure (TFP) sensor F ?? circuit intermittent Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F ?? circuit intermittent Wiring, poor connection, TFP switch, ECM/TCM P0997 Shift solenoid (SS) F ?? control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0998 Shift solenoid (SS) F ?? control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0999 Shift solenoid (SS) F ?? control circuit high Wiring, short to positive, shift solenoid, ECM/TCM Hyundai Specific CEL's P1100 Map Sensor - Malfunction P1101 Map Sensor - Abnormal P1102 Map Sensor - Low Input P1103 Map Sensor - High Input P1104 Air Flow P1105 Air Flow - Abnormal P1106 Air Flow - Low Input P1107 Air Flow - High Input P1108 Fuel Pump P1109 Fuel Pump - Abnormal P1110 Fuel Pump - Stuck On P1110 ETS System - Malfunction P1111 Fuel Pump - Electrical P1112 Manifold Differential Pressure Sensor P1112 VGT Actuator - Malfunction P1113 Manifold Differential Pressure Sensor - Abnormal P1114 Manifold Differential Pressure Sensor - Low P1115 Coolant Temperature Input - Abnormal P1116 Boost Pressure Sensor - Malfunction P1118 ETS Motor - Malfunction P1119 Inlet Metering Valve Control P1120 Electric Governor - Malfunction P1120 Inlet Metering Valve Malfunction P1121 APS PWM Output Circuit Malfunction P1121 Throttle Position Input - Abnormal P1122 Boost Pressure Control Valve P1123 Fuel System Rich - Idle P1123 Timer Position Sensor - Malfunction P1124 Fuel System Lean - Idle P1125 Fuel Press Sensor1 P1126 Fuel Press Sensor2 P1127 Fuel System Rich - Part Load P1127 Control Sleeve Position Sensor P1128 Fuel System Lean - Part Load P1130 Start Solenoid- Malfunction P1131 Injection Quantity Adjust P1134 O2s Transition Time(B1/S1) P1135 Injection Timing Servo P1140 Inlet Air Temperature Sensor Malfunction P1141 Slow Duty Solenoid- Malfunction P1145 Main Duty Solenoid- Malfunction P1146 Idle Co Potentiometer P1147 Accelerator Position Sensor (ETS) Circuit P1150 Barometric Pressure Sensor Malfunction P1151 Accelerator Position Sensor (EMS) Circuit P1152 Accelerator Position Circuit-Low Input P1153 Accelerator Position Circuit-High Input P1154 O2s Transition Time(B2/S1) P1155 Limp Home Valve- Malfunction P1159 Variable Induction System P1162 High Pressure Pump & Fuel Line P1166 O2s (B1) Control Adaptation P1166 Limit O2s Lambda Control (B1) P1167 O2s (B2) Control Adaptation P1167 Limit O2s Lambda Control (B2) P1168 O2s (B1/S2) Heater Power P1169 O2s (B2/S2) Heater Power P1170 ECM (Barometric Pressure Sensor) P1171 ETS Valve Stuck - Open P1172 ETS Improper Motor Current P1173 ETS Target Following Malfunction P1174 ETS Valve Stuck - Close #1 P1175 ETS Valve Stuck - Close #2 P1176 ETS Motor Open/Short #1 P1177 ETS Motor Open/Short #2 P1178 ETS Motor Power - Open P1179 ETS Position F/B-Mismatch P1180 O2 S1 Heater Circuit- Malfunction P1180 Fuel Pressure Regulator - Malfunction P1181 Fuel Pressure Monitoring P1182 O2 S2 Heater Circuit - Malfunction P1182 Fuel Pressure Regulator - Short P1183 Fuel Pressure Regulator - Open P1184 O2s No Activity (B1/S2) P1184 Fuel Pressure Regulator - Power P1185 Fuel Position - Excessive P1186 Fuel Pressure - Too Low P1187 Regulator Valve - Stuck P1188 Fuel Pressure - Leakage P1189 Governor Deviation P1190 Intake Throttle Actuator P1191 ETS Limp Home Valve On P1192 Limp home - Target Follow Malfunction P1193 ETS Limp Home - Low Rpm P1194 Limp Home - TPS2 Position Malfunction P1195 Limp Home - Target Follow Delay P1196 ETS Limp Home - Close Stuck P1300 Spark Timing Adjust Signal P1300 Injector Specific Data Fault P1300 Synchronization Error-CKP/CMP P1301 TDC Sensor - Abnormal P1302 TDC Sensor - Low Input P1303 TDC Sensor - High Input P1304 Phase Sensor P1305 Phase Sensor - Abnormal P1306 Phase Sensor - Low Input P1307 Phase Sensor - High Input P1307 Accelerator Sensor - Range/Performance P1308 Ignition Coil.1 P1308 Accelerator Sensor - Low P1308 Accelerator Sensor Circuit - Low P1309 Ignition Coil.1 - Abnormal P1309 Accelerator Sensor - High P1309 Accelerator Sensor Circuit - High P1310 Ignition Coil.1 - Low Output P1310 Injection Control Circuit Fault P1311 Ignition Coil.1 - High Output P1312 Ignition Coil.2 P1313 Ignition Coil.2 - Abnormal P1314 Ignition Coil.2 - Low Output P1315 Ignition Coil.2 - High Output P1316 Ignition Coil.3 P1317 Ignition Coil.3 - Abnormal P1318 Ignition Coil.3 - Low Output P1319 Ignition Coil.3 - High Output P1320 Ignition Coil.4 P1321 Ignition Coil.4 - Abnormal P1321 Glow Indicator Lamp - Short P1322 Ignition Coil.4 - Low Output P1322 Glow Indicator Lamp - Open P1323 Ignition Coil.4 - High Output P1324 Glow Relay - Malfunction P1325 Glow Relay - Abnormal P1325 Glow Relay P1326 Glow Relay - Stuck On P1326 Glow Relay - Short P1327 Glow Relay - Electrical P1327 Glow Relay - Open P1330 Spark Timing Adjust Signal P1331 #1 MF Signal Line Short P1332 #2 MF Signal Line Short P1333 #3 MF Signal Line Short P1334 #4 MF Signal Line Short P1335 #5 MF Signal Line Short P1336 #6 MF Signal Line Short P1337 #7 MF Signal Line Short P1338 #8 MF Signal Line Short P1340 IFS 2 Open P1341 #1 Ion Line Open P1342 #2 Ion Line Open P1343 #3 Ion Line Open P1344 #4 Ion Line Open P1345 #5 Ion Line Open P1346 #6 Ion Line Open P1347 #7 Ion Line Open P1348 #8 Ion Line Open P1351 #1 MF Signal Line Open P1352 #2 MF Signal Line Open P1353 #3 MF Signal Line Open P1354 #4 MF Signal Line Open P1355 #5 MF Signal Line Open P1356 #6 MF Signal Line Open P1357 #7 MF Signal Line Open P1358 #8 MF Signal Line Open P1372 Segment Time Incorrect P1400 Manifold Differential Pressure Sensor P1401 DMTL Performance P1402 DMTL Motor Circuit P1403 DMTL Valve Circuit P1404 DMTL Heater Circuit P1405 EGR Temperature Incorrect P1415 2nd Air Injection Insufficient (B1) P1416 Secondary Air Injection P1418 2nd Air Injection Insufficient (B2) P1419 2nd Air Injection Valve P1440 EVAP System-Vent Circuit P1440 Canister Valve Open/Short P1443 EVAP System - Tank Cap Missing P1458 A/C Switch Malfunction P1500 A/Con Switch P1500 Vehicle Speed Signal Malfunction P1500 Vehicle Speed Input - Abnormal P1501 Brake Switch P1502 Wheel Speed Sensor Circuit Malfunction P1503 Accelerator Switch P1503 Auto Cruise Control Switch P1504 Inhibitor Switch P1504 Auto Cruise Cancel P1505 Kick-Down Servo Switch P1505 Idle Speed Actuator (Open) - Open P1506 MPS P1506 Idle Speed Actuator (Open) - Short P1507 MPS - Abnormal P1507 Idle Speed Actuator (Close) - Open P1508 MPS - Low P1508 Idle Speed Actuator (Close) - Short P1509 MPS - High P1510 Idle Speed Actuator (Open) - Short P1510 ISC Circuit Open/Short P1511 ISC Open/Short Coil2 P1511 ISC Circuit Open/Short P1512 WTS - Low P1513 Idle Speed Actuator (Open) - Open P1514 Oil Temperature Sensor P1515 Oil Temperature Sensor - Abnormal P1515 ISA Coil1 Command Sig. Malfunction P1516 Oil Temperature Sensor - Low P1516 ISA Coil2 Command Sig. Malfunction P1517 Oil Temperature Sensor - High P1520 Generator Front Terminal Malfunction P1521 Power Steering Switch Circuit P1522 Battery P1522 Sensor Supply 1 Volt - Low P1523 Sensor Supply 1 Volt - High P1524 Sensor Supply 2 Volt - Low P1525 5v Source Voltage P1525 Sensor Supply 2 Volt - High P1526 Sensor Supply Voltage1 - Malfunction P1527 Sensor Supply Voltage2 - Malfunction P1529 TCM Mil On Request Signal P1529 Check TCM P1530 Maximum Vehicle Speed Limiting P1543 Brake Switch Signal Fault P1545 A/C Comp. Switch Open/Short P1552 Idle Speed Act.(Close) - Short P1553 Idle Speed Act.(Close) - Open P1555 Idle Co-Potentiometer Open/Short P1567 Fuel Pressure Valve Current - Low P1568 Fuel Pressure Valve Current - Hi P1569 Current-Pressure Control Valve P1569 Press Control Valve - Current P1586 MT/AT Encoding Sig. Error P1600 Serial Communication - Malfunction (With4A/T) P1601 ECM L Line P1602 ECU-TCU Communication Line #1 Malfunction P1603 ECU-TCU Communication Line #2 Malfunction P1603 ECM-TCSCM Communication Line P1603 TCU Error P1603 CAN Communication Bus Off P1604 TPS Communication Malfunction P1604 No ID From ECU P1605 Rough Road Sensor Malfunction P1605 Acceleration Sensor - Malfunction P1606 Rough Road Sensor Not Ration P1606 Acceleration Sensor - Abnormal P1607 Vacuum Sol. Valve Stuck On P1607 ECM-ETS Communication Line - Malfunction P1607 ECM-ETS Communication Line - Malfunction P1608 Vacuum Solenoid Valve Electrical P1608 ECU Fault P1608 ETS-ECM Communication Line - Malfunction P1609 Immobilizer Communication - Malfunction P1610 Immobilizer - Smartra Error P1610 Sensor Reference Voltage Fault P1611 Mil Request Signal Low P1611 Immobilizer - Transponder Malfunction P1612 Ventilation Solenoid Valve Elec. P1612 Immobilizer - Smartra Malfunction P1613 ECM-Failure P1613 Immobilizer Communication Error P1613 Mil Request Line - High P1613 ECM-Malfunction P1613 ECM (Voltage Regulator) - Malfunction P1614 Mil Request Signal High P1614 ECU Software Fault P1614 ETS ECU - Malfunction P1614 ETS ECU - Malfunction P1615 ETS - ECM Malfunction P1616 Main Relay Malfunction P1619 Main Relay P1620 A/C Relay Malfunction P1620 A/C Comp. Relay - Short P1621 Fuel Cut Valve - Malfunction P1621 A/C Comp. Relay - Open P1622 A/C Control Circuit Failure P1622 A/C Relay - Malfunction P1622 A/C Comp. Relay - Malfunction P1623 Mil Open/Short P1623 Engine Check Lamp - Malfunction P1623 Radiator Cooling Fan - Malfunction P1624 Mil-On Request From TCM P1624 Cooling Fan Relay (Low) Cir P1624 Radiator Cooling Fan - Malfunction P1624 Cooling Fan Relay - Low P1625 A/C Condenser Fan - Malfunction P1625 Cooling Fan Relay (High) Circuit P1625 Cooling Fan Relay - High P1626 Immobilizer Indicator Malfunction P1627 A/C Condenser Fan P1628 Condenser Fan Circuit - Low P1629 Glow Indicator Lamp - Malfunction P1629 Condenser Fan Circuit - High P1630 CAN-Bus-Off P1630 Intercooler Fan - Malfunction P1631 Serial Communication Error - Password P1631 CAN-Time Out ECU P1632 TCS System Malfunction P1632 CAN Bus Off P1633 Immobilizer Status Lamp P1634 Cruise Control Lamp - Malfunction P1634 Auxiliary Heat Relay - Short/Open P1635 Water Heater Relay - Malfunction P1636 Voltage Regulator For Inject. P1638 ECM (Microcontroller) - Malfunction P1639 ECM (Monitoring ADC) - Malfunction P1640 VI Motor Open/Short Coil1 P1640 Main Relay Malfunction P1641 VI Motor Open/Short Coil2 P1642 Non Immobilizer ECU Equipped P1645 Booster Voltage - Operate Injector P1646 Booster Voltage - Too High P1647 Threshold 1 Voltage - Malfunction P1647 Booster Voltage -Too Low P1652 Ignition Switch - Malfunction P1653 After-Run Check Error P1660 Cruise Control Switch - Malfunction P1665 Power Stage Group A Malfunction. P1670 Power Stage Group B Malfunction P1670 Injector Classification P1672 Fan Relay Malfunction - Low Speed P1673 Fan Relay Malfunction - High Speed P1674 A/C Fan Relay Malfunction P1690 Immobilizer Smartra Error P1690 W/Heater Relay Fault P1691 Immobilizer Antenna Error P1692 Immobilizer - Indicator Lamp Error P1693 Mil Request Line - Malfunction P1693 Immobilizer Transponder P1694 Immobilizer ECU Signal Error P1695 Immobilizer EEPROM Error P1696 Immobilizer - Key Mismatched P1697 Invalid Tester Request P1698 Key ID. Not Valid P1700 A/T Gear Shift Malfunction P1701 TPS P1702 TPS - Abnormal P1702 TPS - Malfunction Adjustment P1702 TPS - Malfunction Adjustment P1703 TPS - Low Input P1703 TPS - Open/Short (Ground) P1703 TPS - Open/Short (Ground) P1704 TPS - High Input P1704 TPS - Short P1704 TPS - Short P1706 Inhibitor Switch P1707 Brake Switch P1707 Auto Cruise Brake Switch P1708 Accelerator Switch P1709 Kick-Down Servo Switch P1709 K/D Servo Switch - Open/Short P1710 Oil Temperature Sensor P1711 Oil Temperature Sensor Abnormal P1712 Oil Temperature Sensor Low Input P1713 Oil Temperature Sensor High Input P1714 Idle Switch P1715 A/C on Switch P1716 Steering Sensor P1717 Steering Sensor Abnormal P1717 Steer 1 Input Signal P1718 Steering Sensor Low Input P1718 Steer 2 Input Signal P1719 Steering Sensor High Input P1719 Steer N Input Signal P1721 Control Relay P1722 Control Relay - Abnormal P1723 Control Relay - Stuck On P1723 A/T Relay - Open/Short (Ground) P1723 A/T Relay - Open/Short (Ground) P1724 Control Relay - Electrical P1725 TOD Control Module Error P1726 TPS Input - Loss Of Signal P1727 TPS Input - Out Of Range P1728 EMC-Open/Short To Battery P1729 EMC-Short To Ground P1730 Front Speed Sensor - Low Input P1731 Front Speed Sensor - High P1732 Rear Speed Sensor - Low Input P1733 Rear Speed Sensor - High Input P1734 Speed Sensor Reference - Low P1735 Speed Sensor Reference - High P1736 Shift Motor - Open P1737 ECV Stick P1737 Shift Motor - Short To Ground P1738 Shift System Time Out P1739 General Position Encoder Fault P1740 Position1 - Short To Ground P1741 Position2 - Short To Ground P1742 Position3 - Short To Ground P1743 Position4 - Short To Ground P1744 Lock Up Clutch System P1744 Anomalous Vibration Occurrence P1745 TCM K Line P1746 TCM L Line P1747 TCU-ECU Communication Line #1 Malfunction P1748 TCU-ECU Communication Line2 Malfunction P1749 Serial Communication Link P1749 Serial Communication Link-Open/Short P1749 Serial Communication Link-Open/Short P1750 TPS Communication Malfunction P1750 Front Left Speed Sensor P1751 Not Defined DTC P1751 Front Right Speed Sensor P1752 Lamp P P1752 Rear Left Speed Sensor P1753 Lamp R P1753 Rear Right Speed Sensor P1754 Lamp N P1755 Lamp D P1756 Lamp 3 P1757 Lamp 2 P1758 Lamp L P1759 Control Module - Check Sum P1760 Control Module - Programming P1761 Control Module - KAM P1762 Control Module - RAM P1763 Control Module - ROM P1764 Can Controller - Malfunction P1764 ECU-ITM CAN Communication Line P1765 Torque Reduction Request P1765 Torque Reduction Request P1765 TCS-ITM CAN Communication Line P1766 Torque Reduction Execution P1766 Torque Reduction Execution P1771 Shifting Position P1772 Selection Position P1773 Gearbox Input Speed Sensor P1774 CRC Sensor P1775 TCM-Malfunction P1776 Power Control Module- Malfunction P1777 PCM Output - Malfunction P1778 Electro Valve Output - Malfunction P1779 Stator Inhibit Relay - Malfunction P1780 Push-Pull Sensor P1780 Torque Reduction Required Signal P1781 Actuator P1782 Actuator Position Sensor P1786 Engine Rpm Output Circuit Malfunction P1791 TPS Input Circuit - Malfunction P1795 Ground Return Circuit - Malfunction P1795 Transfer High/Low Switch - Malfunction P1800 Immobilizer Antenna Error P1801 Immobilizer Transponder Error P1802 Immobilizer Antenna Error P1803 Immobilizer ECU Signal Error P1805 Immobilizer EEPROM Error P1805 EEPROM Error/VIN Mismatch P2096 Post Fuel Trim Too Lean-B1 P2097 Post Fuel Trim Too Rich-B1 P2120 Accelerator Position Circuit - Malfunction P2122 Accelerator Position Circuit - Low Input P2123 Accelerator Position Circuit - High Input P2125 Accelerator Position Circuit - Malfunction P2127 Accelerator Position Circuit - Low Input P2128 Accelerator Position Circuit - High Input P2187 Fuel System Too Lean At Idle P2188 Fuel Sys Too Rich At Idle P2191 Fuel Sys Too Lean At P-load P2192 Fuel Sys Too Rich At P-load P2195 L.O2s Signal Stuck - Lean (B1/S1) P2196 L.O2s Signal Stuck - Rich (B1/S1) P2231 O2s Signal & Heater - Short (B1/S1) P2237 L.O2s Pump. Circuit - Open (B1/S1) P2238 L.O2s Pump. Circuit - Low (B1/S1) P2239 L.O2s Pump. Circuit - High (B1/S1) P2243 L.O2s Reference Circuit (+) Open - (B1/S1) P2251 L.O2s Reference Circuit (-) Open - (B1/S1) P2297 L.O2s Out Of Range (B1/S1) P2414 L.O2s Exhaust Sample (B1/S1) P2626 L.O2s Pump Trim - Open (B1/S1) |
Wao it is so great to have this solution because such errors are mostly take much time to solve.
