car bogs down under throttle on rd1
Old Sep 4, 2010 | 08:47 PM
Does it do the same thing if you disconnect the idle air bypass when the car is running?
Old Sep 5, 2010 | 11:06 PM
MakatoMotors's Avatar
Vehicle: 99 tiburon fx
not sure.. but the tps sensor didnt fix it.. i thought it did but it was only because the car was warmed up.
still having the same issues. i did notice this unplugged though.. i looked forever for where it could go but no luck.
(its betweent the plug wires on the coil in the pic) theres 2 of the same thing and ones plugged in (coolant sensor?) but no idea where the other one goes.. can anyone help out? i traced the wire so u can see about where its from and would it be unplugged cause simlar symptoms?
