Bogging
Old Mar 16, 2014 | 04:31 PM
99x3beta's Avatar
Vehicle: 99/ Hyundai /accent
Default Bogging
After finishing my swap. Stock 2.0 in x3
The car drives and runs great when I keep it at low rpm and just cruise it.
But when I get on it the car Boggs and doesn't feel like it should i know this motor should pull a lot harder then what it is and it shouldn't bog
New
Coil pack
Plug wires
Spark plugs
Changed two maf
Fuel pump is new
I have an afpr and fuel pressure is good
Not sure why the car is bogging
Any help is appreciated
Old Mar 17, 2014 | 08:22 PM
Does it have an automatic transaxle?
Old Mar 17, 2014 | 09:45 PM
99x3beta's Avatar
Don't know.. The car is manual so idont think so. If that's what your asking
Update today while driving the car through 3 codes cylinder 2and3 misfire with a random miss fire
That makes no sense I've replaced the whole ignition system..
Old Mar 18, 2014 | 05:17 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Sounds like a bad coil. #2 and #3 are on the same pack If I remember correctly. So it would make sense. I deal with bad, new parts everyday so anythings possible.
Check the connections and wires at the pack, see If It shows signs of getting hot.
Old Mar 18, 2014 | 05:20 PM
99x3beta's Avatar
Ok but it still bogged before last night when it through the code
Old Mar 18, 2014 | 09:18 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
agreed, sounds like bad coil pack, new parts fail too.
not this guy again........
Old Mar 19, 2014 | 05:08 AM
SR Tech's Avatar
Unless the cylinder(s) is just DEAD, the cel won't come on until it sees a certain # of misfires. Just warranty the coil pack and see what happens.
Old Mar 21, 2014 | 10:57 AM
99x3beta's Avatar
makes sense
