Stainless Steel Brake/Clutch Line Gb
Torque spec for the banjo bolt.
Put my clutch line on last night. Now I understand the reason for seasonal fluid change. Blah... Everything fit perfectly for the clutch line.
Here is for the brakes for anyone looking
TIGHTENING TORQUE
Nm
Kg.cm
lb.ft
Master cylinder booster mounting nut
8-12
80-120
6-9
Brake booster mounting nut
8-12
80-120
6-9
Brake booster vacuum hose fitting to surge tank
8-12
80-120
6-9
Bleeder screw
7-13
70-130
5-9.5
Brake tube flare nut, brake hose
13-17
130-170
9-12
Proportioning valve mounting nut
8-12
80-120
6-9
Caliper guide rod bolt
22-32
220-320
16-24
Caliper pin bolt
35-45
350-450
26-33
Caliper assembly to knuckle
69-85
690-850
44-63
Brake hose to front caliper
25-30
250-300
18-22
Backing plate mounting bolt
50-60
500-600
37-44
Sensor mounting bolt on the brake plate (Front)
7-11
70-110
5-8
Sensor mounting bolt on the brake plate (Rear)
17-26
170-260
12-19
Hydraulic unit mounting bolt
17-26
170-260
12-19
Hydraulic unit mounting bracket bolt
17-26
170-260
12-19
Six brake tubes on the Hydraulic unit
13-17
130-170
9-12
Okay, I'm back finally. I'm glad everyone got theirs and is happy!
Yea, Canadian Customs must be a real pita these days. Anyone have their boxes opened by customs?
Everything is new, bolts & washers as well. I don't understand why Eric broke one of the bolts tho. Maybe he doubled up on his Wheaties that day? ;P
Honestly, if your considering reusing the stock bolts, I would compare the orifice sizes on the bolts before I did so. But I've never heard of a problem with the new bolts, so....
Vehicle: '14 Ford F-150
This should be moved to "closed group buys". Opened the thread and clicked the link, expecting to order and found it's closed (even though it's in the "current group buys" forum).
<div class='quotetop'>QUOTE (stauf @ Oct 4 2008, 03:02 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Kits are always available anytime from me via email or pm on any of the forums I'm on. Group buy pricing is over, that's all that is over.</div>
All I'm saying is that if it's over, the thread should be moved. Not saying it should be closed or deleted, just moved to the correct forum so people don't think it's still going on.
