I have worked out this deal with crower to make use R&P for the our tibbys na/turbo
i need at least 10 people the more the merry, they want 800 per set and they have the abitlity to hold up to 800 hp eather I or H beam type turbo or NA after 10 people the price will drop to 678+ shipping this is 200 dollors cheaper then if you call them your self and the pistions will go from 642 to 540 turbo or na also this is a 150 buck extra if you order customs stuff and as far as i know not to many stock our shit i want to know whos in on this... this is a test run to see who is willing as for the shipping i can eather send it direct to you from crower or to Redz |
As long as they will work with the 1.8L beta1 count me in man. Do you have some pics? Will the pistons come with rings? And the rods with bolts? I would guess that they would. Also, can you get like a 82.5mm piston or an 83? Thanks.
$800 for 4 rods and pistons? damn thats good.....what compression ratio will the pistons be? can we get 8.5:1 ? also these are availible for the 2.0 beta?
you guys are silly..
800 only covers rods.. the other price covers pistons.. Crower is a high quality brand name,... you will NEVER see both pistons and rods for 800.. Silly wabbits.. laugh.gif |
<div class='quotetop'>QUOTE (tdonnell @ Oct 20 2005, 02:32 AM) <{POST_SNAPBACK}></div><div class='quotemain'>As long as they will work with the 1.8L beta1 count me in man. Do you have some pics? Will the pistons come with rings? And the rods with bolts? I would guess that they would. Also, can you get like a 82.5mm piston or an 83? Thanks.</div>
yes i that price is for both, and the pistons come with the lock pins and rings as for 83mm size that is not a good ideal you will be changeing blocks every 6 month even here they dont fo 83mm only 1mm&2 mmOS and they only us the 2mmOS in drag cars but any pistion that is over sized will cost 157 more because they must make it to specs and the deal i mad with him is on stock sizes only |
So the pistons will be stock size, low comp?
any word on if they will fit the 1.8l or just 2.0
i doubt many right now have an extra 1200 lying around for pistons/rods....
i would like to be in, but it will be at least 2-4 more months for fundage to be available. |
was there a specific time frame on these?
