Speed Out
Old Jan 23, 2014 | 01:12 PM
Default Speed Out
https://www.buyspeedout.com/
http://www.youtube.com/watch?v=X013r-dQnZ4
Awesome little tool. Wonder if it works as well as advertised. Anyone here use anything like it?
Old Jan 23, 2014 | 02:32 PM
I've got some EZ Outs along with counterclockwise drill bits for this. Half the time drilling the pilot hole with the counterclockwise drill bits is enough to remove a stripped screw or broken bolt.
Old Jan 23, 2014 | 07:14 PM
^this
The other half the time, giving the EZ-out a rap with a mallet to help set the teeth might be required but if you aren't going to use a cutting tool EZ-Outs are usually all you need if you know how to use 'em. Then again, if you have a 'sharp' philips and hit THAT with a hammer a few times, sometimes you don't even have to go find the EZ-outs!
I'm not against this tool, but I would be very hesitant to pay a premium for it.
Old Jan 23, 2014 | 11:43 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Only works if the screw isn't tight.
