I broke my torque dampner
Well, it took it's last shot of nitrous. The braket broke :(
http://i236.photobucket.com/albums/f...s/IMG_0392.jpg |
I was thinking buying one of those too...
looks like i need to make more of those and make a small brace. not like the one i made you before hand but something. i'll call kevin and get a bunch made.
FYI tibbyturbo... I am the one that makes the brackets for the NRG kit. update.... called Kevin, we have ten bent pieces already made, didn't know that. send me your new addy and i will get one out to you man after i weld a gusset on the frontside of it. |
No. The one with the gusset broke my motor mount I think. Didn't we talk about that before or something? I only vaguely remember having it on for a bit and something went very wrong.
no it broke your bolts, did mine also.
replace with grade 5 = no worries. mine is gusseted also bud. |
That's right.. It actually stripped the bolts out of the mount. I had to drill bigger ones in there. I replaced the mount and went back to the original design.
It sounds like somebody needs stiffer roll stops.
. . . of course, then your fillings will all rattle loose again . . . |
Yeah... I tried a solid mount and that sucked. I could hear every little noise the engine made and it was very loud.
I tried poly fill and they were too stiff. I thought this was good. Maybe I can find another mount location. |
The poly was too stiff and the rubber was not. It squeezed the poly out.
Mine stripped one of the motor mount bolt and broke the other. Before I took it off I had troubles with the dampner coming apart. I loved driving with this item but Grade 5 bolts are a requirement for this upgrade. Somebody needs to make sure KFX (Bill) tells people this or more problems will be had.
