Bench Vise question
Vehicle: 01 Tiburon
I find myself in need of a new bench vice as my current one was a garage sale item that has seen more abuse than it deserved. My issue is that all vises share one design element that I don't want: the swivel base is locked in place by friction, provided by a teeny, tiny little handle. I can never apply enough force to keep it from rotating without bending the little handle to a curl.
Anyone know of a bench vise that can be securely locked into position in a series of stops or uses a better locking system?
There are also various degrees of quality to the mechanism that secures the swiveling base. Your old one may slip just because it's worn out. Mine has a handle on either side to tighten the base, and one handle is bent from being cranked with a cheater bar (but it doesn't slip!).
