Up for sale is the following:
Hyper Ground Wires http://www.sigmaautomotive.com/EGS/hotearth.jpg 109.25 These are grounding cables from Sun Automobile. They work hand in hand with the Hyper Voltage System and Hyper Force System. The new Hyper Ground System is the safe and reliable generation tuning system that provides a low resistance ground path. A better ground gives more Torque,better Mileage, better Response, and better Starting Ability. Hyper Ground System is the best performing grounding system available! Sun Auto is the only company authorized to provide high performance grounding system as OEM optional equipment. This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation. In addition "Hyper Ground System" cables have 10 times less impedance than factory ground systems which provides immaculate conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential. The "Hyper Ground System" uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles. What benefits does it provide? <ul>[*]Faster engine start-up : You can feel the difference even with A/C on and at maximum fan speed. This system reduces the loss of electricity to nearly zero at ignition coil and produces better ignition spark. This oscillograph indicates how voltage resistance drops at start-up with the EGS installed (right pic.). More stable idling :[*]You will hear your car engine noise quieter than before. This oscillograph shows the minimized resistance resulting from the installation of the EGS. Note the smaller waves & lower trace in the right pic. [*]Smoother and faster throttle response The upper green lines in both charts below has the Earth Grounding System installed. They indicate a higher torque & horsepower gain. Car used for this dyno test was a Lancer Evolution VI. A max. horsepower gain of 5hp and up has been achieved on a Honda Integra TypeR.[*]Increase low & middle engine torque It helps to achieve a close-to-perfect combustion at low or high revolution of engine, resulting in faster acceleration. A max. torque gain of 0.5kg-m and up has been achieved on a Subaru Legacy BH5. Top image: Red line = no ground / green line = with gound / blue line = with ground + muffler silencer removed. Bottom image: This is done on a Honda Integra Type R. Actual effectiveness varies by vehicle and personal drivability. [*]Better milage In particular city driving. So this system does not just save you money on gas, but very ecological, too. One test even shows an MPG increase of up to 22% on a 1800c.c. test car. Better CPU operation : Cleaner exhaust gas : Lower density of HC and CO. Brighter headlight output : Improvement that you can see. Thanks to a better alternator performance. Improve car audio sound quality : Improvement that you can hear. Thanks to an overall enhanced equipment performance including but not limited to: Car audio, power windows, power sunroof, etc.[/list] |
what is the price?
Sorry, I'm trying to get some stuff posted, and its going up in chunks. I'll update this thread with prices, but I cant give out the price I'm giving until the 28th publically. Its for PMs only. I'll send you info right now. Thanks!
http://www.flyryde.com/sun/HGS2.jpg
http://www.flyryde.com/sun/sunstock.jpg This is the Hyper Ground Wires installed with a HVS GT: http://www.flyryde.com/sun/hvs3.jpg http://www.flyryde.com/sun/hvs4.jpg http://www.flyryde.com/sun/hvs9.jpg http://www.flyryde.com/sun/hvs5.jpg http://www.flyryde.com/sun/hvs6.jpg http://www.flyryde.com/sun/hvs7.jpg http://www.flyryde.com/sun/hvs8.jpg |
| All times are GMT -6. The time now is 07:23 AM. |
