tiburon spoiler
Old May 4, 2009 | 05:25 PM
omeletduefromage's Avatar
Vehicle: 02/hyundai/accent
Default tiburon spoiler
im thinking about putting the oem 03-08 tiburon spoiler on my 02 accent gl. if anyone give me the specs of the inside part of the pillars from inside to inside and then the width of the out side pillars from outside to outside. and if anyone can the width from bolt pattern to bolt pattern. only because idk if the bolts are more located on the inside of the pillars or the middle or the outside. i think it would look nice because its not too low of a spoiler and i dont like the big ass talon style wings.
Old May 4, 2009 | 06:10 PM
It won't fit, not even close. The pillars are outside of the hatch. I have a loose SE spoiler and it'll barely even sit on the Accent.
Old May 5, 2009 | 04:24 PM
yea but i dont have a hatch i have the 4 door so the trunk is much wider. i think the trunk is 51 inches wide. i dont know how wide the hatch is but i think the trunk is wider
Old May 5, 2009 | 04:35 PM
46.5" outside to outside of rear of pillars
50.5" outside to outside of front of pillars
I'll measure whatever else you want if you are sure it'll fit.
Old May 5, 2009 | 05:04 PM
I know yours is a sedan, but here are some mock up pics for your consideration.
Old May 6, 2009 | 06:30 PM
yea i just remeasured the trunk today and its 51 inches across all the way around. but now that i see that the pillars are angled idk how good that would look. im almost positive it will fit. but how long are the pillars? like from the front to the back?
Old May 6, 2009 | 07:23 PM
I think it would look great. Just chop the edges so that it sits flush before you paint it to match the car.
Old May 7, 2009 | 12:00 AM
It's 12" along the bottom of the outside of the pillars and 12.75" along the inside of the pillars.
Old May 7, 2009 | 08:08 PM
wow that actually sounds like it would fit nice. im going to search around and see if i can find a fiberglass replica of the oem spoiler. im trying to save some weight
and thanks a lot for taking your time to take all of the measurements
Old May 8, 2009 | 12:24 AM
The factory plastic spoiler is like 3 pounds MAX. It is crazy light. There is a CF version made but it will have no measurable weight savings.
No problem, if you need anything else let me know.
