One HID is brighter than than the other
I havent diagnosed the problem yet but my drivers side HID light is brighter than the passenger side. I'm going to first try swapping bulbs to see if that's the issue. If not, then I'll try swapping the balasts. If that doesn't work and the drivers side is still brighter, than what else could it be that would be causing the passenger side to be not as bright?
Do as you plan, if that doesn't sort it out (I suspect it will) you should probably relay the headlights.
1 Attachment(s)
Originally Posted by NJ_DRIVER
(Post 713880)
It's probablyy time to replace your bulbs. Here's a chart to give you an idea of lost brightness output over time. |
