HID's wont turn on
My HID's wont turn on, i have everythign conected... both side i pluged int he 3 prong relays i turn on car turn on lights... no lights... i turn on high beams then they turn on but its like on as if they were just normal lights without high beams... wtc?
QUOTE(Renderd @ Jun 17 2009, 05:28 PM)
i even put the stock light in and it worked just fine
It depends on what HID's you got, but 90%+ of the HID kits for single bulb cars eliminate the high beam function when wired up properly. You probably have to hook up one wire differently so that they come on with the low beams.
okay so i started tinkering do what you said... the hi beams work (but those are the factory ones i think or what ever not the HID's) my low still wont work
if you could post pictures that would be amazing, if not thats okay
Which HID kit do you have? You might have bad ballasts, if its a cheap no name kit. Did you just get it, or have you had it for awhile? If you have a voltmeter, check to see if the lights are getting any power to them when you turn them on.
QUOTE(Visionz @ Jun 18 2009, 07:08 AM)
there HID Series H4-H/L, im not sure there brand Bodykits.com called me and sold them to me. no as soon as i got them i tried putting them in... unfortunately i am still settling in so i don't have any cool tools to work with, heh electronics tech with no multimeter
If it's a kit for H4 bulbs it should be right, but there is only one headlight bulb in the Accent housings so unless it's a Bi-Xenon bulb setup the HID kit will generally delete the high beam function.
