Can anyone tell me where the relay is located for the signal and hazard lights? I put my car on the road today but the signal and hazard lights don't blink. I checked the fuse box and have power to every single fuse in there. When I turn on the lights I have power to all running lights, brakes etc, etc. And if I go to signal there is NO clicking sound to indicate the relay is working. So do you think that is what it is, the relay?
that's because the fuse your looking for is in the engine bay........... tongue.gif
The fuse box in your engine bay is located right behind your battery pop off lid (which should have markings on it to tell you what fuse is which. Look for insturment cluster or something rather (i'll take a pic if you have trouble). I DO know that it is a 15AMP fuse (the blue ones) so that'd the kind you need. -patrick |
I checked the fuses in the engine bay and all seemed to be fine. :huh:
then your probably right..it's the relay behind hazard switch. Hazard Switch controls emergency lights and turn signals.
Try webtech if you don't feel like waiting for tibby to reply, or (if you need a new switch) I have an extra hazard switch laying around. -Patrick |
It wasn't me man......Probably another member with a similar Forum name. 02.gif
Just thought.....Stupid me, if that is the case of where the relay is located, because I installed aset of Vent Haloz from Blacktibs over the winter. Who wants to bet that I forgot to plug in the Hazard plug? :blush: :blink: |
that would do it too.........
LMAO, we all do it. Sometimes it's worse, like forget to put gas cap on, oil cap, forget to reconnect battery, forget to plug in coil-pack side of new spark plug wires, forget which wire goes where and end up resorting to the guess and check method, etc. When did you install vent haloz like yesterday? If it was a while ago did your hazard and turn signals work after install for a short period of time? You know what sucks, there's no easy way to JUST take off that dash piece, you gotta go through the whole process. tongue.gif |
No I installed them over the winter while my car was put away. I just got it out for the summer, so I never needed to use the signals till now. lol
ahh, I see...lemme know if you forgot to plug it in or not. If not, I'll take a look at webtech
I won't be able to look at it untill at least tomorrow. I'm at work right now. 02.gif
Thanks anyway. *EDIT* I checked webtech and it says the relay for hazards is located in the passenger side compartment. :huh: Where is this to be found? |
well, I know that the turnsignal relay is down by the clutch pedal. Tomorrow if You want, I will hit the four ways and trace the click. Too dark to do it now.
