Clear Corners: what do I do from here
Old Mar 13, 2005 | 10:29 AM
shark2's Avatar
Default Clear Corners: what do I do from here
http://www.rdtiburon.com/forum/vbgarage.ph...getimage&id=342
http://www.rdtiburon.com/forum/vbgarage.ph...getimage&id=343
Well my main question is just how do i get the lens off (and on)
Old Mar 13, 2005 | 11:33 AM
They are glued on just like the headlights and the taillights. heat and being VERY careful are the only ways to get the lenses off. Unlike all the other lenses on the Tib, the corners are THE most fragile and likely to crack when you attempt to remove them. Trust me, I know...
Mine:
Old Mar 13, 2005 | 12:45 PM
Unfortunately, 8 out of 10 times you'll scratch up the chrome on the reflector or not get all of the yellow out. Just buy some mang.
Old Mar 13, 2005 | 12:53 PM
TibRacer01's Avatar
Yep, I give you props for wanting to do something yourself, but I would just reccomend buying some.
Old Mar 13, 2005 | 01:27 PM
shark2's Avatar
EDIT: But if I wanted the lens off I'd have to stick everything in my pics into the oven?
EDIT: Where's a good place to get clear corners? And why are their two bulbs in the clear corners on importshark? http://www.importshark.com/store/lighting.htm#corners
Old Mar 13, 2005 | 01:36 PM
MK3Design's Avatar
I took apart my old civic healights and made them black. A heat gun is best.
Old Mar 13, 2005 | 02:44 PM
I got my clears off of Ebay about 4 years ago before there was a big demand.. I think I payed 35 bucks for them... as for heating them up, I stuck everything but the lamp, holder, and the rubber drain tube in the oven and let it sit at about 200 degrees until it started to smell...
Old Mar 13, 2005 | 02:53 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
If you wanted to give them a shot take all the rubber pieces and little things that CAN come off before you throw them in the oven. This way you heat up less parts.
As for buying them. Ebay is cheapest but somewhat unreliable. www.kspec.com will be the best, especially with their track record for shipping down to your area.
Old Mar 13, 2005 | 03:56 PM
shark2's Avatar
Are the clear corners on importshark different from the ones on kspec? It looks like the lining of the importshark ones are black but I can't really tell
Old Mar 13, 2005 | 04:20 PM
no, they are the same.
