Accent/Elantra side skirts interchangeable????
Vehicle: 2003,hyundai accent sedan
I need side skirts for my 2003 4 door accent and want to know if the elantra side skirts will fit because I can't find skirts for a 4 door to match the bumper.
Vehicle: 98 Hyundai Accent X3
I'm not sure. I have a 98 Accent and its hard to find kits for mine that don't look the same. I plan on making my own so I know it'll fit.
The other thing you could look into, is..the type of skirting you're interested in. Find out the length of them, then measure your car. If the are longer than yours than you can modify them if needed. Better to be over then under and not sure knowing if it'll fit. I think as long as you have enough length to work with, then I'd consider modifying them.
Good luck. Post pics if you do any custom work.
