xd cam, underdrive pulley ???
Old Dec 10, 2002 | 04:42 AM
turbulence's Avatar
Default xd cam, underdrive pulley ???
how much have the xd cams and pulleys been dyno'd for? i'm just curious. will the xd cam help a lot or a little with a turbo? i plan on piecing a kit together within a year, and i might buy the cam if it's worth it.
Old Dec 10, 2002 | 09:25 PM
Decker's Avatar
the XD cam only helps on a fully modified intake system. ie, its best with CAI BBTB and BIM. You'll probably see a couple WHP with it.
The XD cam is the most agressive cam you can go with with a turbo. Anything more agressive would be dangerous on the valves and springs.
The underdrive pulley (with alot of controversy) will free you some HP in the lowend.
As far as i know, nobody's done a before and after for either of these. Actually i think BV1(correct me if i'm wrong) did do a dyno on the XD cam.
Old Dec 10, 2002 | 10:57 PM
JonGTR's Avatar
I've done a butt dyno on the UR pulley and there is a noticable difference in first gear. It was my first real mod and my wheels came loose a lot easier with it. So to me, that was proof enough. wink
Old Dec 11, 2002 | 05:50 AM
Koreandude's Avatar
How much came out your wallet for the pulley to get the noticable butt dyno? I've seen sets sold on www.nopionline.com for around $300.00 including water pump/powersteering/crank pulley i believe.
Old Dec 11, 2002 | 06:16 AM
turbulence's Avatar
they don't make sets for tibs for some reason. i've only seen crank pulleys.
