Wtb Item To Bypass Govenor/rev Limitor
Old Dec 22, 2007 | 11:33 AM
Midnightsky's Avatar
It's plain and simple, I want to be able to go above my govenor and past my rev limitor. Thus far I haven't found any cheep solutions to this problem but I will not stop looking until I do. Anything extra that you might know which could help me with this problem would be greatly appreciated if posted on this thread. I also don't have a tib, it's a 2.0L 2003 Beta 2 Elantra XD1.
Old Dec 22, 2007 | 11:52 AM
There should be a way. The Governor should be easy if you actually have one. I think ours our only rev limited. As for the rev limiter there may be a way to fool it. Otherwise I am not sure if it cuts fuel or spark but if its spark you could control spark with an MSD box and raise it to whatever you would like. I think there is a way to turn it off, though. Have you searched around here?
Old Dec 22, 2007 | 11:57 AM
our cars have a fuel cutoff not a governer besides once your about 120ish it takes awhile to get anymore speed and its done around 130ish. you need either a turbo or bigger engine to go any faster. our engines just cant take us any faster without more help.
Old Dec 22, 2007 | 12:47 PM
kellysguy's Avatar
I'll take two.
Old Dec 22, 2007 | 01:15 PM
you can try cutting the RPM signal to the ECU and routing B+ to ECU to Hot-At-On power to reset it and keep the CEL off while maintaining the the ability to check for missfires. It might work.
Old Dec 24, 2007 | 03:20 PM
tdonnell's Avatar
Just keep in mind if you have NO rev limiter at all, and you miss a shift your engine will likely go KABOOM!
As far as speed limiting my 97 1.8 tib cut out at 120, the 98 2.0 I have now has gone to 140 without cutting out.
Old Dec 24, 2007 | 03:32 PM
gophins349's Avatar
^^^ wat mods do you have on the 98?
Old Dec 24, 2007 | 04:16 PM
tdonnell's Avatar
Too many to list here, lol.
Check the who's the fastest and horsepower wars threads for my times, dyno slips and info. on mods. smile.gif
Old Dec 25, 2007 | 03:54 PM
BlizagaXx's Avatar
Vehicle: car
TDonnell is the highest modded N/A tib on this site I do believe...
There is a way to get a higher redline, but unless you have every supporting mod there is it is useless. Our powerband pretty much ends at 6500. T had a modded ECU and he could go up to 7800+, but he has EVERY mod pretty much.
Old Dec 25, 2007 | 04:49 PM
tdonnell's Avatar
^^^ Good points, there is no point to reving higher with stock cams/head/etc. unless you just want to be able to go faster in each gear for auto x or track purposes.
Otherwise you will just be accelerating the wear on your internals for no reason.
Even with my headwork/cams/etc. My power peaked at about 7350. Of course after that it only fell by about 5 hp between 7350 and 7800, so it was worth it on occasion for me to wind out the gear to make sure I was still in my max power range after the next upshift. wink1.gif
