Hyundai Aftermarket
-   -   Woo Cares... (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/woo-cares-2603/)
Bringrice Jun 14, 2002 03:49 AM
Woo Cares...
Well im still on the korean voyage to improve the performance of my 2002 Daewoo Lanos hatchback, so far these are all the performance parts that I have: ordered, have but not yet installed, or installed
Bosal Catback
Bosal 4-1 Header
Bosal Performance Muffler
Twin Turbo-Zet
Custom CAI
Removal of Resonator
Powerband modification
I want to squeeze ever last ounce of performance I can out of this little morsel of a car. I plan on getting a 55 shot Zex wet kit in the future.
Ok, I need your suggestions for performance mods, what else can I do that im leaving out in this list? Just dont give me responses like "Get a better car...etc" And yes I know that I have a Twin Turbo Zet rolleyes.gif
Come on people, I hardly ask you for anything , just help me this one time wink
JAWS 021 Jun 14, 2002 04:36 AM
FULL EXHAUST
High flow cat
Upgrade you flexpipe
Screw that cat back
GO with a full,... be a man damnit
Now go, young skywalker
DESIGN Jun 14, 2002 05:47 AM
WTF?
Bringrice Jun 14, 2002 05:54 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>DESIGN:
WTF?</div>I wish I had one of those clever picture things but...I dont..
Get in the loop man
Bringrice Jun 14, 2002 05:55 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>JAWS 021:
FULL EXHAUST
High flow cat
Screw that cat back
tongue.gif</div>I know im already losing a lot of low end torque with the 4-1 header, I figured that if I put the catback on ill recompinsate for the loss, but, as always, im probably wrong
JAWS 021 Jun 14, 2002 06:33 AM
what size is your piping?
Well you already did half the exhaust,... do the other
Get a flexpipe from summitracing.com
Get a highflow CARSOUND cat
And match the piping you have (2.5 or 2.25)
MeetTheCreeper Jun 14, 2002 07:18 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>Bringrice:
Get in the loop man</div>lol, do you mean a camera??
BV1 Jun 14, 2002 07:47 AM
If your headers are like most headers out there they will have a 42mm bore on each header and come together into a 2" pipe at the bottom. The flex pipe you use should match the header diameter (in this case 2") and match all the way to the highflow cat.
If you say have a 2" opening on the header and go to a 2.25" flex pipe and and then a 2.25" high flow cat, you will lose slight performance on the top end because of the lower air velocity in those crucial areas.
Because the flexpipe is so close to the headers and exhaust valves, it still plays are large part in the supercharger effect headers create. If the ports are matched for the header, flex pipe and high flow cat, you will get the best flow and supercharger effect from your headers.
After the cat, it doesnt really matter anyways, then you can go up to 2.5" or 2.25" or whatever you want. The cat will act to regulate the backpressure and long as the diameter on the outtake side of the cat is bigger then on the intake, the engine never really sees whats going on behind the cat anyways.
Just my experience,
-Steve
Bringrice Jun 14, 2002 08:18 AM
Thanks for all your help so far...
Bringrice Jun 15, 2002 02:11 AM
I think im just going to....bump this up a little
