Hyundai Aftermarket
-   -   Vroo...spit Spit....ooooo...spit...m (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/vroo-spit-spit-ooooo-spit-m-40978/)
hamhead Feb 3, 2007 02:11 PM
Iridiums are such a waste of cash.
Copper are 10 times cheaper and you might have to replace them 2x as often.
DTN Feb 3, 2007 06:08 PM
^^ yeah, or go with dilythium crystal. It's supposed to be the best power-core material availble. lmao.gif
most plugs for our vehicles come pre-gapped. You just changed the plugs. why is it almost time to change them again?
Rd1tib Feb 3, 2007 09:16 PM
if its not the plugs, try check to see if ur o2 sensors and maf is koo. My bros 240 was spluttering and spitting out black smoke as well. Just a possibility.
hamhead Feb 3, 2007 09:47 PM
Order I'd do it in:
Pull plugs and check that they are gapped if they aren't pre-gapped
Plug Wires
It could be MAF/TPS but those are sensors that can get a bit expensive so best to do the other stuff first.
Sousake Sagara Feb 4, 2007 05:23 AM
<div class='quotetop'>QUOTE (nemphus @ Feb 3 2007, 02:46 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Umm i dont hink we have an Autozone around here... and i baught the BOSCH Platinum tips.. possibly shi**y plugs... And there is a Hyundai Place in Winnipeg so i think ill go there and get it checked out... But i Have to Wait for a Warm Day... Damn Winter. why should you send your evel snow to attack me!</div>
Did you drop the plugs??......or have them somewhere where they would get rough treatment?? I had a bad miss under acceleration due to a cracked insulator in my '72 Falcon Coupe.
Like alot of people have said so far, check your Wires and Plugs.
IJSTBRNDU Feb 7, 2007 05:51 PM
definately go with iridium plugs...my tech said that many imports don't take well to platinum plugs for some reason.
BlizagaXx Feb 7, 2007 10:08 PM
Flashing CEL means misfire. Pull a plug out and check out if it's fouled up. And don't use Bosch. Bosch is crap. Their plugs are terrible, only use the wires. Check your PCV Valve, air filter, plugs, wires, Fuel filter, MAYBE TB.
