Underdrive Crank Pulley
Yup, looks like it fits. Here's a pic with an OBX that's currently on my 2.0 RD2
http://picasaweb.google.com/radu.rd2/Other...842756823251394
I ran the unorthodox underdrive pulley for years. Only negative I noticed was that when idling, the headlights would dim down quite a bit. Soon as the revs climbed above 1000rpms again, they were as bright as normal.
not really, it is just a matter of your alternator not putting out enough juice at those low engine speeds. I just recommend not sitting with your car idling for long periods of time with the headlights on.
If you like a serious sound system, I would also recommend NOT putting the underdrive pulley on for the same reason. Your alternator needs to spin at at least a certain RPM (not sure what speed) before it starts to produce enough power to take over for the battery
