TPS voltage?
Old Jul 10, 2002 | 05:24 AM
MaDHatteR's Avatar
Default TPS voltage?
Whats an accents Tps voltage read as?
Old Jul 10, 2002 | 05:29 AM
JAWS 021's Avatar
not sure,... but i think its like the tibby
0v-5v
Old Jul 10, 2002 | 05:37 AM
Red's Avatar
Red
Correct. At a fully closed position, the TPS sensor will probably read something around 0.3-0.5v if my brain is working today. At WOT it reads around 4.4v (which pisses off some nitrous systems as it's not close enough to 5v)
Those numbers are accurate for the BETA engines, I would assume the ALPHA engines should be almost the same.
Old Jul 10, 2002 | 06:06 AM
MaDHatteR's Avatar
yeah, im picking out my nitrous system... and it occured to me i have no idea of what some of the readings are.....
thanks
im going to go with the Zex, (4.2V)
Old Jul 10, 2002 | 06:24 AM
JAWS 021's Avatar
kool make sure you have those fuel pressure lines on SUPER TIGHT!!
if not,... you might join me in the ranks of melted plugs
Old Jul 10, 2002 | 07:24 AM
MaDHatteR's Avatar
haha, yeah.... if i mess anything up real bad i'll just put all the stock parts back on take it to the dealer and swear up and down i never did anything to it!!!!
