Throttle Cable Brackets on Airram
Just curious what some of you people with Airrams have fabbed up for throttle and cruise cable brackets. I personally grabbed a piece of diamond plate, ground off the grip and templated a bracket from an '02 elantra to fit. Still working on it, but, was curious what some of you have done.
Mines similar its just a piece of bend and cut steel. Ill take a pick next time Im home.
as long as it functions and can hold up to the tension your good.
Hope so, it's 3/16" thick aluminum. Should hold the tension.
