Throttle Bodies
Old Mar 18, 2002 | 08:20 AM
Nikos's Avatar
Vehicle: 2010 Sonata
Default Throttle Bodies
I'm thinking of installing a new throttle body.I measured mine and if i'm not wrong it's 63mm??? wide.The ones that sharkracing has are 61' the bigest?What's going on?
What's the difference with the Barney Throttle bodies.Should i make any modification to them?The TPS?
Old Mar 18, 2002 | 02:55 PM
MAXXTIB's Avatar
I just think you are measuring the the throttle bodie in the wrong place. You can't measure it right at the opening, it has to be measured where the butterfly is.
Old Mar 18, 2002 | 11:38 PM
Nikos's Avatar
So the 61mm that Sharkracing says is the opening of the butterfly?That goldy thing?
Old Mar 19, 2002 | 12:12 AM
DESIGN's Avatar
Yes the "goldy" thing is the butterfly valve that actually lets air into you engine. The measurement at that point in the throttle body is the important one. The butterfly is nothing more than a flap.
Old Mar 19, 2002 | 02:14 AM
GrAsShOpPeR's Avatar
Vehicle: 2007 Sonata
I am also curious about the difference between the barney TB and the other ones that SR offers. What is the best one to go with taking into consideration money vs. performance. THanks.
Old Mar 19, 2002 | 09:25 AM
Nikos's Avatar
In the pictures that Sharkracing has i can't see the TPS sensor & the cruise control in the Barney Throttle.Instead there are in the pic of the Usual Throttle body.How will i connect those cables if i'll get one of these?????Should i make any modification to the barney throttle body??
Old Mar 19, 2002 | 12:20 PM
NightRaven's Avatar
GrAsShOpPeR:
From SR
Shark Racing Throttle Body
Available for 1996~2001 Tiburon and 1996~2002 Elantra.
Manufactured at 58mm, not bored out to 58mm.
Includes cruise control armature.
Includes TPS sensor for easy installation.
Barney Throttle Body:
55mm~58mm adjustable model for 1.5 liter Accents.
59mm~61mm adjustable model for 1.8 liter and 2.0 liter Tiburons and Elantras.
So from that the barney is adjustable the regular BBTB is not. Also from what i remember the barney does not come with a new TPS or a cruse control armature. However i slightly remember hearing a splurp that the new barneys do have the cruse arm but i am not 100% sure on that.
Old Mar 19, 2002 | 02:02 PM
98tib's Avatar
Vehicle: 2005 tiburon gt
ur stock tb is only 54mm
Old Mar 20, 2002 | 05:35 AM
Nikos's Avatar
Question 1: The stock throttle body of the 2.0lt is the same as the 1.6lt???
Question 2:So if i want to buy the Barney throttle body(The bigger the best 61mm !!) how will i install the TPS & the cruise control on it???
Old Mar 24, 2002 | 08:29 AM
Nikos's Avatar
I found out that the thorttle body of the 1.6lt is exactly the same as the 2.0lt(54mm).
Now for the Barney Throttle Bodies that SharkRacing has how can i found out the way i'm going to install it?Has anyone tried them?Does it worth it's money or it's better the other with the 58mm?
Please guys help me out... wink wink
