Swap problem?
Old Jan 23, 2014 | 07:08 PM
Starter fluid almost wants to burn just spraying it. Drop a hat, it goes. The weakest of spark is probably enough. If you spray it in the air intake, you are bypassing the injectors entirely.
What exactly did you do to test for spark/determine no power to the plugs?
Old Jan 23, 2014 | 07:32 PM
99x3beta's Avatar
Vehicle: 99/ Hyundai /accent
I used a test light just the ones you put to ground. And pointed it in the plug at all wires.
And for spark I took the wire out and connected the spark plug to it and I started the car and I saw the spark jump the gap
Old Jan 23, 2014 | 07:54 PM
If you have sparks jumping the gap, you have power to the coil pack and (obviously?) spark at the plugs. Maybe I'm thick but I don't see what you could do to test anything but the main power wire to the coil pack with a test light. They're for 12V DC not thousands of volts!
Old Jan 23, 2014 | 10:31 PM
99x3beta's Avatar
I know I'm getting spark I need to know why my injectors won't fire. Or not getting power..
Old Jan 24, 2014 | 10:38 AM
If the camshaft position sensor is not reading properly, or is out of phase with the crankshaft position sensor you won't get any fuel. A bad camshaft position sensor has left me stranded.
Did you swap wires from one coil pack to the other to test if your spark timing is wrong?
Old Jan 25, 2014 | 07:16 PM
99x3beta's Avatar
http://www.myhyundaiforums.com/showthread.php?t=410
Here's a link to the same exact problem but I'm guessing this is an lc that he has.
I changed my engine control relay and that didn't help but he's telling the guy to bypass
The relay and supply power to a ? Color wire that isn't the same in my car so I'm pretty confused on which on to give power to
Old Jan 25, 2014 | 09:02 PM
Hyundai was bad about changing wire colors from year to year, it's better to go with the pinout if you can.
Old Jan 25, 2014 | 09:55 PM
99x3beta's Avatar
f*ck my life. Lol so I have two of these cars and I switched the engine control relay from my daily driver and the same thing was happening and then I test for power and power was in the same places I'm both cars so I'm confused my friend
Old Jan 26, 2014 | 01:05 AM
might be a dumb question but what year is that motor and what ecu did you use?
beta 2 has an immobilizer built into the ecu on certain models....
Old Jan 26, 2014 | 11:14 AM
wheel_of_steel's Avatar
Yep, if it has a dildo key then you have to please SMARTRA before anything happens.
Got obd2? Check for dud sensor readouts.
I hear the beta 2 loom and computer uses some faggy sh*t like vehicle acceleration sensors, if that isn't present the ecu will at least be unhappy.
I had your problem with my sohc to dohc swap, turned out to be a bad earth for the main relay. But it could be a billion things as you can see.
