Hyundai Aftermarket
-   -   Stock Vaccum - Common Causes (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/stock-vaccum-common-causes-77546/)
My2000tibby Aug 13, 2014 05:08 PM
2 Questions:
What is the stock vaccum for an RD? When it drops below normal levels, will it throw a code?
My car has been running kinda crappy lately, and getting below average MPG, and I know there are some hoses that could be losing vaccum, but it never throws a code.
Car stumbles occasionally, seems weezy accelerating sometimes, other times pulls strong. I did the fuel filter about 2 months ago, air filter is new, plugs and wires are new, so I'm at a loss.
SR Tech Aug 13, 2014 07:32 PM
18-22inhg at idle
If you have a vacuum leak and your fuel trims go to far out you will throw a P0171-Bank 1 Lean.
I would try running some injector cleaner through the fuel system and sea foam the sh*t out of the intake. Change your plugs again after doing so. Chep enough to do.
Also check and make sure you don't have any brakes dragging. A caliper hanging up will kill your mpg's
i8acobra Aug 13, 2014 08:18 PM
If you have low vacuum in the manifold, it's either a vacuum leak or an obstruction in the exhaust... usually a melted cat.
Stocker Aug 13, 2014 09:51 PM
put a cup or two of 99% isopropyl alcohol in the tank. It could be water in the gas. Alcohol is cheaper than parts!
i8acobra Aug 13, 2014 11:25 PM
If you know someone with a vacuum gauge, checking the vacuum is free.
