Spark plug degree question
Old Jul 17, 2002 | 03:43 AM
JAWS 021's Avatar
Default Spark plug degree question
ok
I have no clue about spark plug temperature... as you can see with my dumbass frying 3 plugs
Im going to be riding around the 200-240whp area
What degree plugs should i use?
keep in mind i have a 10lb bottle in the trunk that im addicted to
I NEED MORE NAWZZZZZ!
my final out put is in the 275-315WHP under nitrous and im expecting torque to reach the 350 mark.
You guys think the zex plugs can handle that?
Im going to have new pistons so the last thing i want is ring damage on my new pistons
I currently run around in my zex plugs... nitrous loves those plugs
havent even dented them
lol
Old Jul 17, 2002 | 10:10 AM
sharkey9883's Avatar
hey, i need to do a spark plug change soon. i plan to go nitrous by the end of the year, are the zex plugs safe to be installed in an N/A car, temporarily? or will it throw something out of balance?
Old Jul 17, 2002 | 12:47 PM
Diambo's Avatar
They run way different than normal ones (I initially had Denso Iridum) my idle became a tiny bit rougher but they run great with nitrous.
Old Jul 17, 2002 | 01:06 PM
Josh's Avatar
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
I too am addicted to the nitrous. I recommend changing the plugs frequently. You don't have to use the expensive zex plugs. I'm using NGK V-power (BKR6E). The recommended model is BKR5E for stock engines. The higher the number, the colder the plug. So it depends on your applicatoin. It runs about 6-7 bucks for a set and I change the plugs each time I change the oil.
Old Jul 17, 2002 | 04:36 PM
JAWS 021's Avatar
ok im familiar with the numbers.... im really curious though on WHICH number should i go to once im putting down 220-320WHP
is it 3 degrees colder? 4? 5?
will the zex plugs still be fine?
BTW... just for your info
i fried 3 plugs NGK vpower that were 1 degree colder... like the ones your using (na 95 eclipse plugs)
be careful
i hope your not running a 75 shot
btw... denso iridiums, i believe suck too
be careful.... i think someone reported a loss in horsepower with those
next time just get the zex... better safe than sorry
i currently have the zex... work like a charm
Old Jul 18, 2002 | 03:28 AM
Diambo's Avatar
I remember a while back trying to get v-groove 2 steps colder but NGK does not even make them, so I went with Zex.
Old Jul 18, 2002 | 03:37 AM
JAWS 021's Avatar
i wonder if the ZEX plugs can hold that much power
they are specially designed for nitrous and turbos
but how about nitrous + turbo at mildly insane levels
Old Jul 18, 2002 | 03:47 AM
Decker's Avatar
what sort of shot are you running? what kind of setup? 100shot? staged?
*drool* *drool*
Old Jul 18, 2002 | 03:56 AM
JAWS 021's Avatar
i think ill go with an extra shot of an estimated 60whp-80whp shot from venom
what ever it takes to push me past the 300whp area for $hits and giggles
im hoping project mitsu gets me atleast 220whp
