Some Engine Building Questions And A Couple Pics
Old May 15, 2005 | 07:26 AM
Viper966's Avatar
ok i started to assemble the motor
got a couple of questions
first one is... did hyundai send me the wrong bearing?
take a look at this picture
you can see that the two outer mains have grooves in the lower bearings...
the middle main has a single oiling hole that matches with a hoke in the block
thats all find
the bearing set that i got from hyundai
it came with 4 smooth bearing surfaces for the 4 outer mains
so thats all done
my question is... the middle bearing cap bearing has another oil hole in it... but there is no oil hole in the cap
is this the right one or should it be smooth like the other four cap side bearings
ok next question is
the thrust bearings... there are two groves in each... like lil notches... do they face out or does the smooth side?
sorry if im just being paranoid
Old May 15, 2005 | 08:34 AM
gmantibby's Avatar
Don't think that hole will hurt anytihng. I can find out tomorrow about the hole and the thrust bearings. I work in a motor shop but I build the heads not the blocks so I will have to ask one of the motor builders.
Old May 16, 2005 | 08:32 AM
Bump for Viper.
Old May 16, 2005 | 10:21 AM
Jaws021's Avatar
it looks exactly like mine..
As far as the thrust washers...
Ill let you know soon... my engine will be coming out shortly...
Old May 18, 2005 | 04:23 PM
gmantibby's Avatar
Bearings with the groove go on the block making sure all oil holes line up. The bearing with the hole for the main cap is ok it will not make a difference. The thrust washers: flat side goes against the block/mains and the 2 grooves face the crank counter weight. Hope it helps good luck!
Old May 18, 2005 | 09:35 PM
2uniq's Avatar
Viper!
I think i have the same bearings as you got and will try to find a pic and post it.
BTW which bearings did you get Oversize or Stock ones for the crank.
I had to use 20 overbore size ones
Also i noticed you didnt notch the Cylinder bores for the Paurter Rods you got.
Make sure you get that done espically for you WHP Goal your aiming for!!!!!!!!
Old May 19, 2005 | 12:50 AM
Viper966's Avatar
QUOTE (2UNIQ @ May 19 2005, 03:35 AM)
Viper!
my block didnt need notching... i have almost a half an inch clearance... it was checked though
Old May 19, 2005 | 04:04 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
what is notching?
PS. Viper, don't quote post before yours. Use ADD REPLY button at the bottom.
Old May 19, 2005 | 10:23 PM
Denisst99's Avatar
your crank bearings are allright
for the thrust washer
the side with the grooves goes toward the crank/flat side against the block
