running rich or CLEAN?!?! WTF!?!?!
Old Sep 23, 2002 | 02:41 AM
JAWS 021's Avatar
Default running rich or CLEAN?!?! WTF!?!?!
Ok...
i was at fontana on saturday
i was in a rush so i can get atleast run ONCE before they closed... i ran into some problems before (nothing engine related)
I managed to switch my plugs for some nice NEW 1 degree colder NGK's v power plugs (nitrous)
Well... i didnt get to run
So **** it... i drove home and i didnt even bother to switch back to stock plugs (regular v powers)
So after 70-100 miles... i switch them back
My findings
cylender 1
Circle thing was black (like it should with a colder plug)
Cyl 2
Circle thing was black... and a bit moist
cyl 3
BRAND SPANKING NEW... it was even sparkling more than my chromies in the sun
cyl 4
BRAND SPANKING NEW
I know cyl 3 & 4 where sparking since the tip of the plug was white
(still burning oil due to rings not settling in yet)
Engine has 1100 miles on it
I looked at my other plugs that ive been using since day one
1-2 some carbon
3-4 A lot cleaner than 1-2
SO WTF>!>!>!>
Could my injectors be dirty?
I did have them dipped in b12 during the engine swap for about a day
I only had 1 side dipped in though (side that points into the engine)
Am i not getting sparks?
WTF!?!?!?!?!
BTW at full throttle my Venom a/f says in running rich
[ September 23, 2002, 10:00 AM: Message edited by: JAWS 021 ]
Old Sep 23, 2002 | 03:11 AM
Red's Avatar
Red
The coils are paired 1/4 and 2/3, so it wouldn't be a bad coil. Time to send the injectors off to RC Engineering, spend the $96 and have them clean and flowbench all four just to make sure.
If it happened on the old motor as well as the new one, then it's probably something in the old hardware.
Old Sep 23, 2002 | 03:23 AM
JAWS 021's Avatar
Red thats the thing
In my old engine i had carbon rings all the time... even with nitrous
ON ALL 4
Im guessing that the B12 chem stuff screwed things up
Since i only had one part of the injector dipped... maybe the "junk" began to collect
But i believe the b12 dissolves that stuff... so that would be a problem...
Oh well
Im checking my plugs tonight
These are clean and will have 100 miles on them
and they are Regular v powers
Could it also be the wires?!!?!
Maybe 3 & 4 are fine... and 1 2 are just not sparking???
Oh wait... i just switched the wires with some new stock ones... although they are a tight fit on the new beta
I think it will be cheaper just to buy 2 used injectors... turbo goes in a month along with 550cc NEW injectors
[ September 23, 2002, 10:24 AM: Message edited by: JAWS 021 ]
Old Sep 23, 2002 | 03:31 AM
Red's Avatar
Red
Howabout instead of buying new ones, just switch the existing ones around. If you flip the injectors around so that 1/2 are now on 3/4, then (supposedly) the problem should follow the bad parts.
By 1100 miles the rings should have fully seated. Get the engine warm and do a static compression test to see if there are any problems on the 1 and 2 cylinders.
Old Sep 23, 2002 | 03:46 AM
JAWS 021's Avatar
Im planning on doing a full diagnostic on tuesday
Im thinking 3 & 4 are my problems
im thinking when i cleaned the injectors all the gunk went to the bottom (which is the part that points into the cyl)
Ill check
thanx red
Im curious... im going to pull my plugs when i get out of work and see what they look like after 75 miles
Hopefully it was just the gapping or something on the plugs
BTW isnt there an Injector failure CEL?>?>?>
I havent gotten one... so maybe its not as bad as im thinking it is
[ September 23, 2002, 10:49 AM: Message edited by: JAWS 021 ]
Old Sep 23, 2002 | 07:44 AM
JAWS 021's Avatar
BTW... could it also be that my wires are bad???
They are new... but they are stock hyundai wires
So they could be faulty
I guess i wont know until tonight
Old Sep 25, 2002 | 05:37 AM
Koreandude's Avatar
Try checking the wire resistance to see, but i'm not sure what is the acceptable Ohm range is per wire....
