returnless sys pros and cons?
Old Sep 10, 2002 | 02:24 AM
Electrichead's Avatar
Default returnless sys pros and cons?
what are the pros and cons of having a returnless fuel system?
Old Sep 10, 2002 | 02:25 AM
2001 Accent's Avatar
con, putting extra fuel into the engine is a hard process
Old Sep 10, 2002 | 05:22 AM
skierd's Avatar
Vehicle: 1997 accent L
Pro's: lower emissions
simplicity and fewer parts
Cons: can't use a fuel pressure regulator to add fuel for hi powered forced induction setups
limited choice of hi flow fuel pumps
One is not better than the other, but return systems can be easier to tune if you're on a budget. Returnless systems usually require going the more expensive route of larger injectors and ecu trickery (or a standalone ecm).
