Replacing Gearbox Oil And Brake(clutch Fluid)
Hi guys.
Its been a while.
I want to do a oil service on the engine, gearbox aswell as the break fluid.
I know how to do the engine oil change.
But gearbox im not sure.
In my idea this is how its done:
For Clutch or break fluid:
Ok this is from thumb-sucking. But seems right.
Can anyone help?
Its been a while.
- Remove 1 bolt from gear box and let oil drain..
- Remove Speedo drive sensor
- Put bolt back and refill.
- Attach pipe on clutch slave bleeder.
- Release the bleader bolt.
- Press clutch until all the fluid is out.
Can anyone help?
1st off I think there is tons of info on this if you would care to search....
As for the tranny...
-What are you gonna put in it?
--I used RedLine MT-90 from summit racing. Got three bottles.
But you only need 2.3 quarts
There is a drain bolt and a fill bolt I believe.
17mm bolt to fill
24mm bolt to drain
Why are you removing the speed sensor?
Thats a start.
I found all that in less than 2 mins you find the rest.
17mm bolt to fill
24mm bolt to drain
Thats a start.
