Relocating O2 sensor without cat?
i'm installing my headers and exhaust later this morning, and there's a chance that I might not be able to put the cat on(wrong size), if I put the second O2 sensor behind my resonator on my Speedstate exhaust, would the CEL still come on, or does it have to be a cat?
thankx guys
thankx guys
yes, the CEL will still come on. The second O2 is to check for a lower voltage and therefore verify that the cat conv. is working. If they both send the ECU the same voltage, then . . . CEL.
A temporary solution is to wrap the second O2 element in foil and secure it under the car. This is highly illegal (as is driving without a cat). However, it will avoid a CEL for the time being.
It sounds like you are stand-up (at least from the EPA's perspective
) and will have a cat on there soon enough, so this should be a temporary fix.
The loss in backpressure (which helps scavenge the crap out of the cylinder) from not having a cat will probably have you wanting it back on ASAP. Shane at MHP (back in the fxtreme days) had a supercherger and removed the cat, and put it back on becasue of the loss of low end torque.
Sorry for the long reply. Hope this helps,
ac
) and will have a cat on there soon enough, so this should be a temporary fix.The loss in backpressure (which helps scavenge the crap out of the cylinder) from not having a cat will probably have you wanting it back on ASAP. Shane at MHP (back in the fxtreme days) had a supercherger and removed the cat, and put it back on becasue of the loss of low end torque.
ac
