Rd1 Problems Re-arise, Stalling, Won't Idle.
#22
I went and checked the plugs today, they all look great, and I know they have less than 10K on them, prolly less than 3K.
I'm going to try the plug wires now, then the drivers seat is coming out and I'm gonna get on my back to see if I can repair any of that wiring mess down there.
UPDATE!
Faithofadragon came by, we did the following.
1. Swapped Coilpacks with mine. No fix.
2. Swapped Crank Position Sensor with mine. No fix.
3. Lost several bolts and nuts, found most of them. LOL No fix.
4. Sparkplug Wires, no fix, but they look GREAT.
After taking the drivers seat out, and looking at the ECU harness, it's worse than I thought. It's horrible to be honest with you. I'm truly sad. We will be trying to do multimeter testing on the sensors this week, and patch up what we can in the dash area, but I really could use a new ECU harness with about 2 feet of cable included.
UPDATE!
#23
and just to reiterate
its REALLY bad
were talkin ________/_____/_______/
with the / being where there is a cut in the wire ON THE SAME DAM WIRE seriously there are like 4 cuts within 6 inches of wire or so
im thinkin of just cuttin the dam harness and remaking it its so bad under there
its REALLY bad
#24
BTW, I just went and started looking at some of the wiring diagrams for the ECU Faith, half of the wires that are all f***ed up are EXACTLY WHAT IS CAUSING THE PROBLEM.
Grey = TPS SIGNAL WIRE.
There are a few others, but that one is the kicker, and that is one of the absolutely worst ones.
#25
well at least we know what it is
i was thinkin maybe we should cut that harness out and fix the wires that way were nut under the dash cutting, crimping and replacing wires....
cut it out
fix the wires in your workbench
then recrimp everythin back in i sware there has got to be at least 15 friggin messed up wires under there
cut it out
#28
got wire near the ecu connector and in the harness until the wire is "good"
solder in a new piece of wire,use shrink tubing over to isolate it,repeat process for other wires
no need to change the whole harnessm
does this car had an safc,rev/speed meter,smt-6 or something like that before?
#29
it had a safc before
mang seriously there is alot of damage on these wires
and the damage is to almost all of the wires buying a new harness connector is startin to look like a good idea
#30
QUOTE (faithofadragon @ Mar 5 2006, 09:54 PM)
That's what I'm thinking. Or a version of it. I'd like to cut out what's down there now, as far away from the ECU as possible to get as many of the damaged sections of wire out of there as we can. Then, with a NEW harness connector and a long pig tail of extra harness, prep and tin the ends of the wire on the bench and put shring tubing on all of it and push them down the wire. Get back in, without connecting the ECU, and re solder each and every one of the wires, then slide the shrink tubing over them, one at a time, and seal them up for good.
QUOTE (cysco00 @ Mar 5 2006, 09:58 PM)
See..now you guys are feeling my pain.....LOL. That is why I bought a Toyota instead. owned.gif
Cisco C.
Cisco C.
Yeah, but you were lied to. I never got to get under the dash man. You had told me when you had the problems that all of the wires were soldered in place for the SAFC, there are NO solder points down there at all, no solder anywhere on those wires. As for what you told me last night about the guys at Hyundai repairing it all for you, it didn't happen. They put some electrical tape on a few of the splice points, but that's it. There is no heat shrink on 90% of the damage down there, and they didn't repair any of the splices, they just wrapped it in place. That's why you had the problems, the TPS being bad was part of it, but the 'covered up' wire damage was the rest. BTW, you bought the Nissan first, ya noob.
QUOTE (faithofadragon @ Mar 5 2006, 10:00 PM)
mang i wont let this beat me...
it will be back even if i gotta pull the dash off to fix it!!!
Me neither. Now that we know what the problem SHOULD be.
And if THIS dash comes off, it's going back on. LOL
QUOTE (Denisst99 @ Mar 5 2006, 10:37 PM)
You gotta see it. There is one wire cut about 3 inches from the ECU, and it's got a bullet connector done on both ends of it. Why? No clue. There's several other wires with big gashes in them from someone trying to tap the wires with the wrong size wire tap. There's also several wires only holding on by 2 or 3 single strands of copper, in several places. To fix this right, we are going to have to do it this way. As for the SAFC 2, yes, I put in the first post it's had 2 of them in there before I bought it.
Now I just gotta find a harness.
Faith, you have a soldering iron? I've got some solder.
