Hyundai Aftermarket
-   -   Pulleys (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/pulleys-3128/)
9o7TiB7o9 Jul 27, 2002 05:38 PM
Pulleys
Just need a quick question answered. What are the benefits and what are the problems with the Unorthodox Racing Pulleys that KORE sells?
JonGTR Jul 27, 2002 09:04 PM
No problems with them. It's 95+ degrees right now and my a/c works just fine. The only downfall is $200 for about 5 h.p. and .1 seconds off your time. Is it worth it? It's up to you.
2 UNIQ Jul 27, 2002 09:58 PM
<div class='quotetop'>QUOTE</div><div class='quotemain'>JonGTR:
No problems with them. It's 95+ degrees right now and my a/c works just fine. The only downfall is $200 for about 5 h.p. and .1 seconds off your time. Is it worth it? It's up to you.</div>Why wouldnt it be worth it?
I have had mine for over 2 years with NO PROBLEMS AT ALL!!
Gaining 3-5 WHP as i did was pretty good and for $200 this is not expensive.A CAI will give you about the same HP gain and cost just as much or more.
I would defently recommend it BUT if you have a System in your car your this would be the downfall but not that noticable.I had a MASSIVE system in my car 2 years ago and had the pulley installed at that time and my Headlights would DIM if i was at a stop light with the music BLASTED.As long as your car is moving you would be fine as it will charge.Other than that if you dont have a System or BLAST your A/C you will be fine!
9o7TiB7o9 Jul 28, 2002 03:22 AM
