Pulleys
No problems with them. It's 95+ degrees right now and my a/c works just fine. The only downfall is $200 for about 5 h.p. and .1 seconds off your time. Is it worth it? It's up to you.
JonGTR:
Why wouldnt it be worth it?No problems with them. It's 95+ degrees right now and my a/c works just fine. The only downfall is $200 for about 5 h.p. and .1 seconds off your time. Is it worth it? It's up to you.
I have had mine for over 2 years with NO PROBLEMS AT ALL!!
Gaining 3-5 WHP as i did was pretty good and for $200 this is not expensive.A CAI will give you about the same HP gain and cost just as much or more.
I would defently recommend it BUT if you have a System in your car your this would be the downfall but not that noticable.I had a MASSIVE system in my car 2 years ago and had the pulley installed at that time and my Headlights would DIM if i was at a stop light with the music BLASTED.As long as your car is moving you would be fine as it will charge.Other than that if you dont have a System or BLAST your A/C you will be fine!
