Please Help With Cel!!!!!!!!!!!!!!!!!!!!!!
Old May 28, 2005 | 10:01 PM
oh, well still probably a short in the wiring. you just know its one of the two heater wires now.
Old May 28, 2005 | 10:07 PM
CyberShark's Avatar
Ahhh, more time to spend on the car I guess..I am so frustrated with this. The CEL first came on right after I intalled my first header over 2 years ago and has been here ever since!
Old May 29, 2005 | 12:55 AM
albert's Avatar
check your wiring for the 02 sensors. If it first started when you installed the header, check for damaged wiring to the 02 sensors.
Old May 29, 2005 | 08:04 AM
sharkev's Avatar
I also still have the po134 code, but you say that your code is po135, right?.
when i check that i replaced the first o2 sensor and I still have the po134 code.
i check everything and i still dont know what could be the wrong. now IF you guys can tell me if I CAN NOT be nitrous with this problem???, i have never thought this before.
I also saw that the last way to try to fix that is replace the ECM.
thanks
and sorry about the question.
Old May 29, 2005 | 08:06 AM
albert's Avatar
It could be the ECU is the problem, but chances are it's your wiring somewhere. Verify that you've got 5V running to the Front 02 sensor at the wiring connector. If you don't, keep following the wiring back until you pick up 5V. If you follow it all the way back to the ECU and you STILL don't have 5V. Then you KNOW its the ECU's fault, not the o2 sensor's fault.
Old May 29, 2005 | 01:48 PM
sharkev's Avatar
^^ ok, but in which wire do I have to get 5V? sensor signal or heated sensor heating?
right now I am check that but i also dont know if I have to check this with the engine on or just with the ignition on.
random?
p.s will matter if I have the SAFC installed in my car?
thanks
Old May 29, 2005 | 09:30 PM
i know the signal works on a 0-5 volt scale, but not sure about the heating cricuit. testing the heater circuit would show up as 0 though if there was a short, so as long as you get a reading, you should be fine.
Old May 30, 2005 | 12:48 AM
albert's Avatar
Guys, it's REALLY simple.
There are 4 wires.
1 negative/ground
1 Positive 5V
1 Signal Positive (+)
1 Signal Negative (-)
The signal wires only carry between .1V and 1.3V That's it.
If you're getting .1 to 1.3V that's occilating, those are the signal wires. Try the other wires.
Old May 30, 2005 | 07:59 AM
sharkev's Avatar
^^ok. yesterday I tested 2 wires, i guess it was the ground and one of the signals.
so today or tomorrow i will test the other two.
iam doing this with the ignition on.
thanks.
Old May 30, 2005 | 10:49 AM
albert's Avatar
Do it with the car running. Just disconnect the front 02 sensor at the wire connector (yeah, you'll get a CEL).
And probe/check the 4 connections inside the wire connector. If you've got 5V there, then plug the 02 sensor back in, and check it way down by the sensor itself.
The ECU won't send the 5V to the O2 sensor unless the car is running and cold.
