Ontario station mistakenly pumps diesel instead of gas; damages multiple cars
Video in link
http://news.yahoo.com/video/ontario-...233000636.html Ontario station mistakenly pumps diesel instead of gas; damages multiple cars It was a horrible mix-up for some drivers in Ontario as a service station pumped diesel fuel instead of gasoline, which caused multiple cars to be damaged. How pissed off would you be? What exactly happens to your engine if you pump diesel through it instead of regular and how bad is it to fix? |
It'll just run terribly for a little while then quit running for the most part. Gotta siphon the tank and run gas back through the lines. It's nowhere near as bad as gas in a diesel engine.
^ what he said. Although, if it leaves you stranded in a blizzard you could die from exposure.
