Non Cruise To Cruise Control
my current tib does not have cruise control. this is very bad cuz my foot is very heavy...
i was wondering if it was possible to make a vehicle have cruise control. if so, what is needed?
i'm assuming first would be a TB. then wiring it from the TB to a button in the dash... would there be anything else? how hard would it be? would it be worth it? has anyone done it? so many questions...
i need cruise!
i need cruise!
Might not be too bad if the wiring is already in place. Still a lot of parts to gather though...
Actuator
Clutch switch
Stop lamp switch
Cruise control module
Vacuum motor
Cruise main switch
Pulley assembly
Speed Control Switch
Actuator
Clutch switch
Stop lamp switch
Vacuum motor
Cruise main switch
Pulley assembly
My car has an after market cruise system fitted that works fine. It was already fitted b4 I got the car, but it doesn't look hard to fit. The TB still has the single pulley and both cables go to it.
QUOTE (REDZMAN @ Jul 1 2005, 03:31 PM)
Really shouldn't be too hard mang.
when it comes to wiring and electrica crap... it should be hard for me. haha
i'll leave it in the back of my mind... maybe when i see another parts car on here
and i would have to completely replace the "speed control switch," right? (this is the right side thing on the steering wheel. the one w/ the wiper blades as well
took cruise off one and put on another tib. np all the wireing is already set up to have it preaty much all you need to do is plug the stuff in. the tb is the biggy. by dad took and made it so the 2 moved together but every now and then one cable would slip off and the engine would just rev and rev untell it hit the limiter. had to turn it off and pop the hood to put it back on and then go on about what i was doing. we found a replacement tb though, problem fixed. but yeah. it only took him a day i think. only slow part really was console and wireing work.
if you can get a hold of wec2002 (i think is his name on here) he can tell you any and everything you would need to know. he has put in 2 cruise systems now.
