Hyundai Aftermarket
-   -   No Speed Gauge And Odometer. (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/no-speed-gauge-odometer-44174/)
Whiplash Jul 21, 2007 05:22 PM
Whats the part called that needs to be replaced once the speed tach and odometer stop working on a 99 tib?
DTN Jul 21, 2007 06:13 PM
That's a pretty vauge question man.
Tachometer, speedometer, instrument cluster, speed sensor, ECU.... am i getting close?
Whiplash Jul 21, 2007 06:35 PM
Anyways, the speedometer and the odometer stopped working. Same thing happened when I had my tib. I just forget what the part is called.
REDZMAN Jul 21, 2007 08:52 PM
Probably the little gear that goes into the tranny to send the signal to the speedo.
Denisst99 Jul 21, 2007 10:03 PM
did you check the fuses?
Whiplash Jul 22, 2007 09:18 AM
My dad was playing around with the fuses because the wipers stopped working. Then when I turned the car on and drove off I noticed the speedometer and odometer werent working...
Do you know which fuses might be to blame?
DTN Jul 22, 2007 09:26 AM
I've had my cluster loose before and the gauges stopped working.
Check fuse 10. The speed sensor is not the problem. It must be fuse 10.
http://hmaservice.com/GRAPHICS/E2/E27B320A.jpg
http://hmaservice.com/GRAPHICS/E2/E27B320C.gif
Dmitry Jul 23, 2007 01:45 PM
I bet it's something with fuse or wires.
DTN Jul 23, 2007 02:28 PM
I just re-read the symptoms. Is the speedometer the only one that does not work, or is it the speedometer and tachometer?
Tibbychick Jul 23, 2007 02:42 PM
My odometer hasnt worked for the past 2 years. I dont know how much mileage my car really has 02.gif I think I checked the fuses though, since thats what I was gonna suggest for you to do. Other than that I dont know.
