No Oil Pressure
#21
If it's expanding on the topic, it's ok to bring up an old topic, even though it's also perfectly Ok to start your own topic.
This bothered me. We used to have a part number listing around here but I couldn't find it. I searched a few other sites and then google and couldn't find it. This took longer than I care to admit, seeing that research online is a huge part of my job, but I think I have found your part. Unless I am very much mistaken, it is #21135 in this diagram:
And it's Non-Return Valve, stock #2113523010 approximately $17 allegedly for sale here:
http://www.jimellishyundaiparts.com/...113523010.html
But I'd call them first before placing an order, to be sure they have it in stock.
N.B.: The voices tell me this check valve is missing from the Beta II but you might want to verify that... be sure you need it, before you install this part!
#22
Vehicle: 01 hyundai tiburon
That is exactly the part I need. The engine got so hot that the plastic keeper melted from the oil. When the head came off the spring disappeared and all that's left is the ball and casing. I called the dealer and they found one in chicago. It should be here in two days. Its a pretty big jump going from small block chevys to these.
