new gaskets needed?
Old Aug 27, 2002 | 11:27 AM
tibboy316's Avatar
Default new gaskets needed?
for my direct port i have to take off the intake manifold i do believe so when i put it back of anfter all the taping and **** is done do i need to get new gaskets for it?
Old Aug 30, 2002 | 03:19 AM
you should get new gaskets unless the old ones came off in PERFECT condition, regardless of what gasket you are talking about.
Old Aug 30, 2002 | 04:44 AM
I've removed/reinstalled my IM about 5 times. Never had a problem re-using the stock IM gasket. It's damn durable and really doesn't go through much stress. It should last the life of the engine.
If you REALLY want to replace it, you can. No harm in a nice new gasket.
Old Aug 30, 2002 | 05:16 AM
tibboy316's Avatar
there is harm all i have is 100 bucks left right now lol i think ill try to make this new one on
if you could tell me how u took it out wihtout breaking it i would appricate it
Old Aug 30, 2002 | 05:31 AM
Ego's Avatar
Ego
tibboy316:
¿Que? Not sure what you're trying to say here--the gasket is damaged? Or you're poor so you would rather try not to damage it?
I just unbolted the IM and it fell away clean, leaving the gasket stuck to the block. I wiped the gasket down with a fairly clean cloth before I bolted it back up, but never even tried to peel
it off.
I suppose that if it doesn't come off to clean, you'll want to peel it off the IM carefully. Use something like a drywall spatula or thin chisel or knife if you have to, just scrape it off the surface carefully.
